390 camshaft replacement
Old Apr 2, 2008 | 12:04 PM
blueovalboy_69's Avatar
blueovalboy_69
I have a recently rebuilt 390 and I am not satisfied with the bottom end so I am looking to replace the camshaft. It has an edelbrock 750cfm carb and an edelbrock aluminum intake meant for idle to 5500rpm. It has stock rebuilt heads and high compression pistons and headers. I was wondering if anyone had any advice on what kind of cam would work best?
Thanks Blueovalboy_69
Old Apr 2, 2008 | 02:29 PM
65f100_352's Avatar
65f100_352
The comp 268 would be a great cam for your truck. 1500-5500rpm. Has all the low end you need and a lot more top end than stock. PN# 33-224-3 for the cam and K33-224-3 for the complete kit.
Old Apr 2, 2008 | 03:22 PM
Bear 45/70's Avatar
Bear 45/70
Replace the 750 carb, it's too big and hurts the bottom end. A 600 will work better and is good to 5300 and just how often do you really need to run 5500. FYI, that 7500 is good to 6600 RPM and you don't need it. Besides the 600 will improve mpg. I agree with 65f100_352's recommendation for a cam, unless the cam you have now is in the same ball park, then you problem is overcarburation, a common one BTW.
Old Apr 2, 2008 | 04:56 PM
blueovalboy_69
Thanks
Thanks I will take you guys advise and order up that cam!
Old Apr 3, 2008 | 08:26 AM
blueovalboy_69
I ordered the comp 268H cam but in the description of it it said that it was meant for 9:1 compression and under and that any higher compression would just work against the cam; my engine is running at about 10:1 or a little higher is this something to worry about?
Old Apr 30, 2008 | 08:51 PM
9299Fords's Avatar
9299Fords
blueovalboy ... did you find any information on the 10:1 vs 9:1 compression and cam effectiveness?
Old May 2, 2008 | 01:22 AM
ricky27330's Avatar
ricky27330
I am putting the comp 280 cam in mine got it off e-bay cam and lifters for $123.00 brand new cam i was lookn earlier today and saw a another one
Blueoval_boy_64
Jan 22, 2009 05:53 PM
BlueOvalBoy
Nov 9, 2005 05:47 PM
Blueoval_boy_64
Offroad & 4x4
Oct 6, 2004 05:32 AM
powderspecial600_98
26
Aug 10, 2004 11:17 PM
chrowen
Jan 7, 2004 02:24 PM
