Pros and Cons to '94 7.3 Turbo Diesel
Old 10-12-2004, 05:03 PM
Stubbs's Avatar
Stubbs
Stubbs is offline
I am looking at a '94 7.3 Turbo Diesel F-350 and was wondering what the pros and cons might be on such? Got fairly screwed by not doing enough research on my last purchase and I am trying not to make the same mistake twice. It isn't a powerstroke that I know of, believe it is just one of the pre-powerstrokes.
Any and all advice for a buyer would be great, thanks guys!
Old 10-12-2004, 07:55 PM
dieseljoe's Avatar
dieseljoe
dieseljoe is offline
i have a 94 f350 dually crew cab and i love it has alot of power and drives nice for a truck
Old 10-12-2004, 08:14 PM
94f2507.3td's Avatar
94f2507.3td
94f2507.3td is offline
i have a 94 f250 4x4 super-cab that i bought 6 or 7 months ago ,and i love it.its all stock xcept clutch . plenty of power and decent fuel mileage also
Old 10-12-2004, 10:58 PM
Stubbs's Avatar
Stubbs
Stubbs is offline
What do you think you get on average for your gas mileage? At the moment I currently own a '99 Jeep Grand Cherokee, All Wheel Drive, and average about 13/16 city/hwy.. It really bugs me, but I got a great deal and can sell it as of this moment and come out ahead in the deal, and have always loved diesels. Found a decent deal on a '94 F350 and figured I would look into it.
Thanks for the answers guys.
Old 10-13-2004, 07:52 AM
BikePilot's Avatar
BikePilot
BikePilot is offline
I just bought a 94 F250 4x4 supercab long bed with a IDI TD and 4.10 gears. I drove it back from FL yesterday and tested the mileage. Here is what I got...the truck was basically empty...one motorcycle in the bed and pulling a jetski on a trailer.
Cruise Controll set at 70mph (about 2250rpm) --> 13mpg
Cruise Controll set at 60mph (about 2000rpm) --> 16.5mpg
Cruise Controll set at 55mph (about 1800rpm) --> 21.3mpg
All of the above figures were obtained in very similar moderately hilly conditions on the same day and were tested for more than 100 miles. I never found the limit of its power....even on some of the steeper grades the cruise controll held it at whatever it was set for without downshifting or slowing at all. I suspect that the higher speed mileage figures could be improved with the ATS turbo outlet housing and downpipe (and mabey a gear vendors overdrive).
Good Luck
Josh
Old 10-13-2004, 09:12 AM
Ironpants's Avatar
Ironpants
Ironpants is offline
I have a SRW CC F350 turbo '94 (IDI) with E4OD automatic behind it.
I perfer the ZF 5 for a tranny, but oh well.
These are fairly easy trucks to work with, however the power generating modifications take money. It certainly is not a powerstroke.
Is it an auto, or stick shift?
How many kilometers (miles)?
CC, extended cab, or reg cab?
Nothing beats sitting above the traffic on my daily commutes (200 kilometers / day). I fill both tanks every 4 days, however I just changed my injection pump and I expect to get better milage.
I have an F250 '91 stock 7.3 L with ZF 5 that I can get 800 kilometers on both tanks at highway speeds (110 km/hour).
Generally if I drive above 2100 RPM, on the highway, I find I am just wasting fuel....
Old 10-13-2004, 09:59 AM
grtF250's Avatar
grtF250
grtF250 is offline
I'll agree with everyone else here they are/can be good trucks.
Before you buy questions you could ask are:
1) Check the SCA additive in the coolent. Does the current owner know what it is, did he/she use it. (lookup cavitation and coolent additives here, you'll find a lot)
2) What work has been done to it. new IP, batteries, etc.
3) Ask about oil consumption / look for leaks older engines do use some oil, and i'd guess there are some leaks but make sure its not excessive.
4) There have been a number of posts on looking to purchase these rig's in the past. They would be worth a read.
Old 10-14-2004, 02:30 PM
Stubbs's Avatar
Stubbs
Stubbs is offline
Thanks for your help guys, some very informative information.
Old 10-14-2004, 03:24 PM
89ford73's Avatar
89ford73
89ford73 is offline
i have an 89' with 4.10 gears and a 93' with 3.55 gears. the 4.10 gears run 2700 at 70, the 3.55 runs 2200 at 70 if it has 3.73's(rare) then it will run 2400 rpm at 70. i think someone just told him that the truck has 4.10's to sell the truck. it really has 3.55's so make sure if you want gas milege you get the one that runs 2200 rpms at 70 in overdrive.the turbo is really controvercial thing. i helped a guy take the turbo's off 4-94's and they all seemed to run better after the mod, they pulled better, i don't know about the fuel milege, but they did seem to run better. check the coolant, if it is pretty green, thats a good thing, if its nasty brown, thats a bad thing. make sure it starts all right, tell the guy you want to meet him at 7:00 in the morning and watch it start when the engine is cold. if he alredy has it good and warmed up for you, tell him to keep it. if it is automatic and the tranny works well, its a rare thing. stick with the standard if possible. the trannies are good trannies, but people abuse them too badly and they do funny things. also, if you floor the truck with no load on the engine, it should run smooth, not rough like i have seen some, this means the injection pump and injectors are iff-ey. hope this helps you
Old 10-16-2004, 03:25 PM
Turbo Indian's Avatar
Turbo Indian
Turbo Indian is offline
I'm seriously thinking about selling our 03 6.0 psd & going back to a 93-94 idi td. if that tells you any thing about those 2 years
Old 10-18-2004, 07:40 AM
BikePilot's Avatar
BikePilot
Want to trade???
1994 F-250 extended cab, IDI TD, 4x4, E4OD.
Old 10-18-2004, 07:46 AM
Turbo Indian
Originally Posted by BikePilot
Want to trade???
needs to be a f350 4X4 crew cab. I had what you have & loved that truck,but we need the crew cab.
Old 10-18-2004, 07:49 AM
BikePilot's Avatar
BikePilot
I understand....I wanted a crew cab also..but this one was a really good deal and I didnt actualy need the crew cab (its just me and my fiancee right now). I am hoping to put on the ATS turbo housing and down pipe this winter, but it depends on available funds (getting married in Januarary )
cds
21
06-12-2020 05:35 PM
Bibo_1st"Truck"
05-31-2016 08:31 AM
Alek Merkoulov
1978 - 1996 Big Bronco
03-03-2016 04:48 PM
nmhs
17
06-11-2013 01:30 PM
quality1const
06-17-2007 12:42 PM
Quick Reply: Pros and Cons to '94 7.3 Turbo Diesel
