Pop and Creaking
Old Oct 6, 2004 | 08:53 AM
TurpinD's Avatar
TurpinD
Pop and Creaking
Just bought a very clean 1994 F250 with 37,000 miles on it. Clean as a pin. Auto, 460 . But, I have a pop and creaking sound or snap sound coming from under the cab. I looked at the ball joints and tie rod ends. They look good. Kind of sounds like a frame bolt or cross member bolt.
Any thoughts
Old Oct 6, 2004 | 09:04 AM
Fordfanz's Avatar
Fordfanz
only thing I can say is get under there and start pulling on crossmembers driveshaft and such
Old Oct 6, 2004 | 09:54 AM
haybine's Avatar
haybine
my 1993 F150 had the same type "popping or creaking" noise since it was new up until about 6 months ago. checked everything under the cab, around the tranny and mounting and the front end parts and never did find the source of the noise. it finally just quit making the noise. everything seems to be alright. dunno what it was. welcome to ford!
Old Oct 6, 2004 | 07:41 PM
coplin's Avatar
coplin
read this helped alot
Try this:
https://www.ford-trucks.com/lc/lc.ph...d_trucks.shtml
Old Oct 6, 2004 | 08:07 PM
92lightning's Avatar
92lightning
My truck had a poping/clunk sound when I hit a bump or hit the brakes.It was the Radius arm bushing's. They looked worn so I ground off the heads and drilled out the rivets. It tightend up the stearing and quieted it doun.
Old Oct 6, 2004 | 09:36 PM
aikigod's Avatar
aikigod
The transmission crossmember is notorious for loosening and causing popping sounds...
Old Oct 6, 2004 | 09:57 PM
Sawbones25's Avatar
Sawbones25
Huh?
Old Oct 6, 2004 | 10:17 PM
turboincanada's Avatar
turboincanada
I have and 88 f250 which was driving me crazy with its popping sounds going over speed bumps, tight turns and generally whenever it felt like it. Finally tracked it down to be the transmission crossmember when I repeatedly drove up on a wood block with one front wheel only and had a buddy find the source. Be careful doing that. I then put 2 extra 3/8" bolts through the crossmember and frame on each side. A year has gone by and the popping noise has quit even though I off-road quite a bit. Might be the same problem you have. Worked for me.
Richard
88 f250 4X4 351 twin turbo
Old Oct 6, 2004 | 11:05 PM
andym's Avatar
andym
Popping noises can be caused by SO many things. Check all the suspension parts, front and rear, U-joints are a popular one, and especially sway bar bushings on the older trucks. They like to rot out.
F350GK
Feb 18, 2016 11:37 AM
daddylee100
Feb 21, 2014 06:43 PM
tdpower
Jun 16, 2012 06:45 AM
MoreBoostPlease
Jul 14, 2011 04:10 AM
66 Ranger
Apr 3, 2003 02:18 AM
