low end
Old Sep 29, 2004 | 07:16 PM
Mcyktor98's Avatar
Mcyktor98
low end
I put a flowmaster 40 series DI/DO and then dumped it on my '95 250 with a 351. I used to be able to rip my tires off with no problem what so ever. Since I put on this muffler I feel like I lost some low end but the power is still there just higher up in the RPM range. Is this common? Any help will be appreciated. Thanks
Old Sep 30, 2004 | 07:35 PM
coker0290's Avatar
coker0290
yea its common when you lower the backpressure.
Old Sep 30, 2004 | 08:15 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite
it common to LOSE torque when you decrease backpressure? for some reason i dont think thats right....
Old Sep 30, 2004 | 11:17 PM
Mcyktor98's Avatar
Mcyktor98
Is it because I have the exhaust dumped and do not have tail pipes? Would it help if I got some tailpipes put on? thanks
Old Oct 1, 2004 | 04:09 PM
kens64's Avatar
kens64
No its not... Backpressure is not good, therefore, losing some will NOT cause you to lose torque.
You didnt mention the pipe size you used.
Old Oct 1, 2004 | 07:35 PM
Samsonitesamsonite
lol i thought i was goin crazy, if anything you might have picked up some low end
Old Oct 1, 2004 | 10:20 PM
coker0290's Avatar
coker0290
i ment that the torque has moved up the curve. you lose some lowend torque but gain mid rpm torque.
Old Oct 2, 2004 | 11:02 PM
Mcyktor98's Avatar
Mcyktor98
I just put a muffler on. that is it. Stock pipes, although I would like to get headers and a high flow cat. Seriously though, I feel like I lost a little off of the line. Anyone have any information. thanks
Old Oct 2, 2004 | 11:18 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Talking
On Monday I am taking my truck in and having a Flowmaster 50 series, single in - double 2½" out and straight out the back end. I'll let y'all know if I think I gain or lose bottom end. I'd think it would increase bottom end power a bit. But it still wouldn't matter, because if I had a better mid range torque, then passing and hills would be quicker and easier. We shall see...report Tuesday...either here or in user announcenents forums. I'll probably talk a couple pics and put in my gallery, also.
Old Oct 3, 2004 | 01:15 AM
kens64's Avatar
kens64
If thats the case, I would look into other possible causes. Just changing the muffler shouldnt make such a difference. I have gone through several mufflers looking for the sound I want, and I couldnt tell the difference in any of them power wise.
Old Oct 3, 2004 | 10:56 PM
Mcyktor98's Avatar
Mcyktor98
I just want to know if I put tailpipes on it if it will make any type of difference. If it will I will put them on. Can anyone also tell me what I can do with my catalytic converter to lose some backpressure. Will a high flow cat make a real difference. What about an X-pipe or h-pipe. Will those do anything for a couple extra horses?
thanks
Old Oct 4, 2004 | 04:08 AM
kens64's Avatar
kens64
A high flow cat will almost always flow better than stock. An X pipe is good for a few ft/lbs, and IMO, helps out the sound a lot too.
Old Oct 4, 2004 | 05:02 AM
Broncojohn's Avatar
Broncojohn
Just throwing this one in the mix. I've alway been told duals = HP and 2into1 = torque a crossover tube will also help. I did notice a difference on my Harley but never experimented on my trucks, I've alway run 2 into 1 2.5" exaust.
Old Oct 4, 2004 | 11:02 AM
pwgabor's Avatar
pwgabor
I had a Ranger with 2.5l and had a flowmaster 40 si/si. Well with a tailpipe it did great, but then I dumped it and lost a lot of lowend torque. Try putting on the tailpipes and that should help some.
Old Oct 4, 2004 | 05:48 PM
Fordlover55
Still kicking!!
Picked truck up from the muffler shop a bit ago. I had a single in double out Flowmaster 50 series installed. It sounds GREAT!! I took her out on the highway, did some acceleration from a stop tests and to be truthful I can't tell a difference in bottom end, but she seems to start out in 2nd a bit easier than before. Went to 2½" pipe, also.
Soodude
Modular V10 (6.8l)
Jul 18, 2011 07:53 AM
Microchudd
Nov 15, 2009 12:12 PM
Kuskoal
Exhaust Systems
15
Dec 1, 2007 01:06 PM
cvanover
Jun 15, 2005 07:50 PM
astamp78
Mar 20, 2001 05:42 PM
