transmission trouble?
Old Nov 12, 2009 | 02:03 PM
Microchudd's Avatar
Microchudd
Hello, all.
I have a question about my pickup's transmission.
My truck is a '75 F100 running a 302 V8 and a C4
auto. Recently I noticed that when I come to a complete stop and then go to pull out of an intersection my truck is still in high gear instead
of downshfting to low like it should. I can manually put it down into low and then put it back into Drive and it will work fine. I will pull out of somewhere and it will pull out slow and then kick down into low gear and take off , hopping the rear end of the truck in the process.
Old Nov 14, 2009 | 11:43 AM
classicfordman's Avatar
classicfordman
it could either be a fluid and filter problem, a modgulator valve issue, or worst case your bands could out of adjustment
Old Nov 14, 2009 | 12:54 PM
jk080's Avatar
jk080
Transmission Rebuilder
Most wrong gear starts are caused by a sticky governor.
You will have to remove the extension housing to get to the governor. Remove the governor and take it apart and clean it.
Old Nov 14, 2009 | 12:58 PM
Microchudd's Avatar
Microchudd
transmission trouble..
OK thanks guys ... one question.. where is the extension housing located??
1975 F100 Custom
2WD 302 V8
Old Nov 14, 2009 | 04:29 PM
jecsd1's Avatar
jecsd1
I agree. remove the tailshaft housing and verify the governator valve isn't stuck
Old Nov 15, 2009 | 12:12 PM
classicfordman
yes i had forgoten about the governor...lol...that would do it too...lol
kylbbb22
Jan 31, 2014 03:55 PM
hustler54
Dec 26, 2013 03:05 PM
ckrichard
Apr 27, 2006 02:57 PM
LA_BigRed
28
Feb 28, 2005 07:41 PM
Bruce P
Nov 22, 2004 04:55 PM
