No Low-End Power
Old Jun 12, 2005 | 02:27 PM
cvanover's Avatar
cvanover
Question No Low-End Power
I bought an '85 Ford F150 4WD with an inline six cylinder. I took the inline six out and replaced it with a 302 from an '84 Mustang GT, inwhich has been newly rebuilt from the ground up about a year ago. I have also put on a set of 33x12.50x15 tires on 10 inch wide rims. My problem is... I have a Holley Truck Avenger carb on a stock aluminum intake and it feels like there's not a whole lot of power on the low-end. What can I do to get more power on the low-end if that's the problem? And what's the difference between a 500 and a 600 cfm? Someone said that the carb that I have just might be to big for my purpose, I don't really know!
Old Jun 13, 2005 | 10:50 AM
TxBrokenarrow's Avatar
TxBrokenarrow
you may try a carb spacer to give it more low end...(4 hole 1")over size tires will make a truck dog at the start..a gear change may help...does the carb work good after it gets going??
Old Jun 14, 2005 | 09:40 PM
LxMan1's Avatar
LxMan1
Advancing the timing as far as possible without detonation will help. The stock carb on the 5.0 HO is a 600 cfm.
Old Jun 15, 2005 | 07:50 PM
cvanover's Avatar
cvanover
I was thinking about going with the Edelbrock Performer Series intake and carb setup for more low-end power, I think it's like from idle to 5500r's. What do guy's think?
Chris
Kustomfiend
Aug 28, 2012 11:49 AM
I6power
Feb 4, 2005 11:52 AM
jmms
Aftermarket Products
Aug 8, 2003 10:38 PM
crawlfish
May 31, 2003 09:37 PM
Wojo
Aug 17, 2000 09:29 PM
