Engine Block Heater Wattage
Old Dec 16, 2008 | 12:20 AM
  #31
FordSavvy's Avatar
FordSavvy
Here's what I Know..Have a '06 6.0l from the manual and the dealer it says warm up the truck 3 hrs before start in 20 deg and below. The heater draws 17.3 -17.6 amps. I have a 20amp with 12-2 wire dedicated circut outside plug. It is not a GFI so it can't pop due to moisture and screw me in the morning start up. Also have a 20amp timer and use a 50ft 12 gauge extention cord so I don't loose any amps. A lot of the problems people are having with not hot enough is the alotted time and under amped outlets and cords. It is a world of difference when I plug in from when i forget and don't. And a side note to "Smokin'" -- I think most will agree --You really are Smokin HOT!
Old Dec 16, 2008 | 12:30 AM
  #32
KelVarnson's Avatar
KelVarnson
That seems kinda high, are you sure about that number? That's about twice the power of the 7.3 block heaters.
BTW, Welcome to FTE!
Old Dec 16, 2008 | 12:38 AM
  #33
twags6's Avatar
twags6
That number is extremely high. The block heater on the 7.3's is only around 800 watts (6 2/3 amps). I could see taking 10 amps off your readings and they'd sound right.
clintusaf
21
Mar 2, 2015 11:57 AM
03shadow350
Jul 30, 2009 06:36 AM
Oregon Bob
Aug 11, 2006 09:10 AM
New To Ford
2004 - 2008 F150
Jul 25, 2005 01:03 PM
knucklehead11
Apr 23, 2003 12:02 PM
