Oh man if it's 1150 I am in trouble. Let me explain. We are in the process of building a house up in the woods of Maine and my power for up there is 24 batteries through and inverter charged by solar panels. I have 60 amp service but if I have to run this for 2 hours to heat up the engine then I will drain the batteries in no time. I will have to figure out something else. Hopefully the new batteries I put in the truck this summer will help. It seems that one of the ones in there for last winter wasn't pulling its weight and that is why I had a hard time starting when it got cold out.
If you have fresh batteries, and you're sure your glow plugs and glow plug relay are ok, you shouldn't have to plug it in. Do some searches on here for info about testing the glow plug relay and glow plugs and give them a check to make sure they are all working properly.
OK will do but at -40 I would think that having it warm is a necessity. Last year there were quite a few cold nights with a stiff wind that would have made the wind chill even lower, but that is another story.
Ouch. At -40 I think you do have to be concerned about plugging it in, and possibly even adding an oil pan heater too.
(Nitpick: wind chill doesn't mean anything to an engine. It will affect how long a warm engine will stay warm before it is as cold as the outside temps, but it can't get any lower than the actual outside temp.)
Yeah, I thought of that. I already have a 3kw Honda so that is most likely what I will end up using for the real cold mornings. I will just have to get up and go out real early and then be wide awake after coming back in.
At -40 it's almost time for a sweater. I personally wouldn't be as worried about the block heater as much as the fuel gellin up in the tank/lines. You shouldn't have to plug the truck in for 2hrs to get it warm enough to start, those heaters warm things up pretty quick, although I have not experimented at that cold of temps. I am willing to bet that plugging it in for even 1/2 to 1 hour will warm it up enough to start just fine. Try it at a 1/2 hour, and if no go, give it a little longer until it cranks over fine.
Last winter I had to wait for 2 hours to get it warm enough to crank, but that was with the batteries that were getting old. I now have 2 1000 cranking amp hour batteries in there so I should have some good power this winter.
I talked to my solar guy and he suggested using the little generator also so my plan now is to try to crank it once and if not power up the generator and heat up the block. Hopefully between the new batteries and a check of the glow plugs it will be in tip top shape this year.
I should have synthetic but don't. I can tell you that last year once it started it knocked for a bit until the oil loosened up. Once we are up there full time I will be using synthetic all the time in it. For now we only go up weekends and the ocasional week. Last year we happened to be there one of the coldest weeks they had. There were a few days where the high temperature for the day was -10. It got a little chilly riding the snowmobile on those days.
Hopefully by the time we are ready to move up there I will have been able to build my garage. Now if only those lottery numbers would come in....................
The generator is what I do for cold cold nights. Something else you can do is get a lower wattage magnetic heater to stick to the oil pan, then you can run off your solar. Most efficient way to do it is get a 12V heater, then you would not have the efficiency loss of converting from 12V to 110V. I like to start it with a couple cycles of the glow plugs in the afternoon each day when temps are reasonable.
Where are you on Moosehead? I drive by there, then Kakajo, then 30mi on the Golden road to get to my camp on Chesuncook. Snowmobile access only in the winter though...
