EGR Disconnect Instructions
Old Jun 28, 2004 | 09:25 AM
  #31
purplewg's Avatar
purplewg
Originally Posted by jdadamsjr
The thread hasn't died !!!
We've just all been driving our EGR'less trucks!
Disconnected it last week and no check engine lights on my 05/03 Ex.
Dang, how does that 05 motor run? How hard was it to stick in the 03 Ex.?
Old Jun 28, 2004 | 10:02 AM
  #32
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Maybe built in May of 2003
Old Jun 28, 2004 | 10:15 AM
  #33
jdadamsjr's Avatar
jdadamsjr
Now I KNOW you know betta than that
I'm just confused about what year model I have...
hope it's an 05 but knowing it's a beast of an 03...
I find it hard to believe I've had that thing for a year already !!!
And still having fun with it afte 30K miles
Old Jun 28, 2004 | 04:32 PM
  #34
n6nfg's Avatar
n6nfg
throttle plate removal effect engine braking in tow/haul?
Does the removal of the throttle plate effect the engine braking effect in tow/haul mode with the auto transmission? I tow, and would hate to see any decrease in engine brake efficiency as a result of the throttle plate not being able to be closed.
I am guessing that not only do the turbo vanes close down, but probably the throttle plate is also closed during tow/haul braking. Anyone confirm?
Old Jun 28, 2004 | 04:40 PM
  #35
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Did not effect mine. Even with mine disconnected it will bark downshifting from 3rd to second. Seemed to have no effect on it at all.
I suppose the reason I am an advocate of disconnecting it is all the good it did for mine, both in terms of performance and economy. Nothing drastic, but nonetheless noticeable. The only thing that is "abnormal" is 2 measly trouble codes. Some havent had quite as much luck as I have with it.
Old Jun 28, 2004 | 09:24 PM
  #36
bighoss550's Avatar
bighoss550
my tow/haul was not affected
Old Jun 29, 2004 | 07:51 AM
  #37
derek witt's Avatar
derek witt
I am going to unplug EGR as well but am a little confused regarding noise level. In many previous threads I have read that people feel that there truck may be a little louder after unplugging EGR, now in a couple of responses here, guys feel it may be a touch quiter. Is there any mechanical reason why it may be quiter/noisier ? Can anyone confirm their noise level ?
Also, by having the EGR unplugged, will the truck take longer to warm up? (important here in our cold winters) Thanks for any responses.
Old Jun 29, 2004 | 11:25 AM
  #38
SpartanDieselTech
Former Vendor
Whats your year model and build date?
Old Jun 29, 2004 | 11:44 AM
  #39
derek witt's Avatar
derek witt
Truck is two weeks old. Build date is May/04. It also has a different 04 1/2 model year flash as well because at a local diesel performance shop here, they tried to load a Superchip Tuner program and it wouldn't load no matter what. Afterwards they said Ford had a different flash or system out for the 04 1/2's . That is the first I've heard of that.
Old Jun 29, 2004 | 12:35 PM
  #40
SBV45's Avatar
SBV45
I have heard that Ford is about to release a new flash. But I have been hearing that since January. It is possible there is a flash that is going in new trucks but not released in the wild yet.
Old Jun 29, 2004 | 04:46 PM
  #41
IB Tim's Avatar
IB Tim
For what year an 03 or 04
Old Jun 29, 2004 | 06:43 PM
  #42
SpartanDieselTech
Former Vendor
Maybe my new stock motor will have it. I doubt it will be alot different from the previous 04 flash, as it seems to be pretty much "clean" in terms of problems. I doubt it will have PI.
Hopefully I will know pretty soon!
Old Jun 30, 2004 | 11:11 AM
  #43
SpartanDieselTech
Former Vendor
I really cant come with an answer for you on this one. Some seem louder (mine seemed a little bit) but alot of other people report otherwise. Unplug it and just see if you like it would be my best answer to that. You can always plug it right back in if you dont, its about a 15 second procedure
Old Jun 30, 2004 | 01:11 PM
  #44
jdadamsjr's Avatar
jdadamsjr
Maybe I'm WAY off base here... but I'll post it anyway :-)
Seems to me that stopping the exhaust from going back into the intake stream would make the truck more effecient in that the exhaust gases CAN'T burn as well as a pure charge of diesel...
MY take on it is that it should burn a little better....
so maybe that DOES make the explosion more violent, but more effecient, and therefore needs LESS to do more :-)
Old Jun 30, 2004 | 01:14 PM
  #45
SpartanDieselTech
Former Vendor
Same here. Good thoughts. There is no way exhaust gas (which has already been burned, thereby deprived of oxygen and full of soot and carbon) can burn as efficiently.
