EGR Disconnect Instructions
Old Jun 25, 2004 | 03:59 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Originally Posted by FredsF250TD
Don't have much time but one more thing to think about, the PCV gasses. These, mixed with the exhaust gasses from the EGR is what causes the mess in the TDI's intakes. What about venting the PCV gasses into a catch can instead of into the intake? I'm assuming our motors vent crankcase gasses into the intakes?
I bet there is a way to vent BOTH of them outside the vehicle. Im not sure about the EGR as there is not really a way to splice the system, however it is a good idea. This way, no codes would be thrown at all.
Old Jun 25, 2004 | 04:12 PM
bighoss550's Avatar
bighoss550
pcv gasses in a turbo/aftercooler system do have a benefit. everything in the intaketract is coated w/ a light film of oil. same as a K&N.(filtering) and no rust is present. but if u want rid of it elsewhere, a 30deg angle tube in ur DP is the only "legal" way to do it(like a race car). EPA doesnt like the "evaporative emissions" being vented.
Old Jun 25, 2004 | 04:47 PM
SBV45's Avatar
SBV45
Any check engine light? If you get a chance, pull the codes and see if you got the same two that I did. I think if we all get to work on this, we can totally kill the codes.
No check engine light. I'll chek codes with my Predator tonight.
Old Jun 25, 2004 | 06:04 PM
SpartanDieselTech
Former Vendor
Ive been searching the 6.0 Bible over, and I just cant find anything on the PCV...anyone know where its located?
Old Jun 25, 2004 | 06:17 PM
psdwanabe's Avatar
psdwanabe
The SES light should only come on with the CA emissions equipped vehicles. The way some get around this is to hook up another EGR valve, big$. You can get a failed one from the dealer if you know a tech. Install the failed one on the engine, (make sure its failed closed) hook up your good EGR to the connector, no codes, no lights. Theres another reason for going this route. The EGR works in conjunction with the VGT actuator, with the EGR disconnected people have reported about a 1 psi loss of boost at WOT. When the ECM detects the EGR is not functioning properly (it does have a feedback loop) it must go into some sort of limp mode, limiting boost at WOT. Ive heard a couple of people report this, they have decided to just hook it back up.
As far as the VW TDI. My son and I cleaned his Golf TDI intake a few months back. The intake where the EGR gasses enter is about 2.5", it was so coked up there was about a 3/4" hole remaining! I couldn't believe it was still running let alone getting 45mpg. It had 80K miles on it at the time.
Old Jun 25, 2004 | 06:21 PM
03 SuperDuty FX4's Avatar
03 SuperDuty FX4
PSD 60L Fx4, I think the 6.0L diesel doesn't have a pcv (Positive Crankcase Ventilation).
psdwanabe's Avatar
psdwanabe
Its comes from the left valve cover and enters the intake pre-turbo. Many have rerouted (7.3 and 6.0), but it puts out so much mist they end up reconnecting. Some have rerouted it to the rear axle, in a can, with a filter, and it still is pretty overwhelming. There is a system sold that does a good job of separating the oil from the air, reroutes the oil back to the engine crankcase. Its fairly expensive though.
Old Jun 25, 2004 | 06:34 PM
psdwanabe's Avatar
psdwanabe
I found the system. Look here.
Old Jun 25, 2004 | 07:36 PM
SpartanDieselTech
Former Vendor
That is cool. Im gonna look into that some more. Until you guys enlightened me here, wasnt even aware of the PCV.
Old Jun 25, 2004 | 07:37 PM
SpartanDieselTech
Former Vendor
Lose boost? That is odd. We need to look into this.
When one of you guys (with a boost gauge) gets a chance, unhook the EGR and compare it to your hooked-up boost. Let us know if there is any difference between the two. I will try it myself as soon as i get my truck back and pick up some gauges.
Old Jun 25, 2004 | 11:25 PM
SpartanDieselTech
Former Vendor
I have been trying to determine exactly what kind of valve the EGR valve is; solenoid, ect. I am going to order an EGR puller tool from ford when i return to the dealer to pick up my truck. If it is a mechanical type valve, the valve could probably be "chopped" where as the mechanism still triggers but the valve does not actually open.
As for the PCV, Im still trying to do some more research on it, when i get a little spare time.
Old Jun 27, 2004 | 11:11 PM
SpartanDieselTech
Former Vendor
Well, since this thread has about died...
Everyone that has disconnected their EGR please post your mileage (total, then miles with EGR unhooked) and the effect it seems to have on your vehicle
Old Jun 28, 2004 | 07:13 AM
  #28
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
This will take time now, it has peaked and will settle down then .................start to get more responses over time. Threads actually have a reactively predictable life….
It is a great thread!
Old Jun 28, 2004 | 08:12 AM
  #29
Diesel Cruiser's Avatar
Diesel Cruiser
Accumulated Miles: 18,458
Miles with EGR unplugged: 4,764
Effect: Maybe a little quieter. Maybe a slight increase in MPG, but that could be ongoing break-in mileage improvements. My reason to disconnect is HOPEFULLY to not have a gunked up manifold like VW TDI's get.
Since no one has come up with a good reason to remove throttle plate except an opinion about a non-technical, undocumented performance change: "This is simply an obstruction to airflow, and is useless when the EGR is disconnected", I would think that if Ford finds a throttle plate removed and the EGR unplugged that they would have another case to wash hands where they choose for warranty, but if the wire to the EGR was easily replugged and everything else was intact they wouldn't have much to go on. Your truck, your investment, your call.
  #30
jdadamsjr's Avatar
jdadamsjr
The thread hasn't died !!!
We've just all been driving our EGR'less trucks!
Disconnected it last week and no check engine lights on my 05/03 Ex.
Do have the P403, P404, & P405 EGR and the P603 KAM codes according to the predator... but no negatives noticed with the disconnect...
And maybe it's perception for me since I knew it is disconnected,
but my wife didn't know it and she commented that it seemed like the engine "got quiet again" .... not like when the pilot injection was still there, but it is a perceptual difference
MPG improvement ??? maybe a bit... but I NEVER watch the mpg anyway so I wouldn't be the one to notice any diff.. if it does improve, fine... but no big deal to me
Overall - worth the 10 seconds or so to disconnect... but I'm not the type to dive into the throttle plate removal either... almost like work to me
