C6 vs FMX Trans
Old Sep 6, 2004 | 04:50 PM
sullyda1's Avatar
sullyda1
C6 vs FMX Trans
I am considering changing the FMX in my 67 F100, 352 ci with a C6 transmission. Summit Catalog lists a C6 for the FE motor at $750 + shipping. Does anyone know if an FE type C6 will directly bolt in place of the FMX. I would also be changing the torque converter and flex plate.
Old Sep 6, 2004 | 05:29 PM
ford390gashog's Avatar
ford390gashog
yes the c-6 will work as long as you use the right bellhousing for a fe engine
Old Sep 6, 2004 | 07:34 PM
sullyda1's Avatar
sullyda1
Are you saying the FE FMX bell housing won't work? The C6 has it's own FE bell housing?
Old Sep 6, 2004 | 07:47 PM
fellro86's Avatar
fellro86
it is part of the C6 case, as it is one piece. There are 2 tailshaft lengths as well to keep in mind, the short tail is likely the one you will need to have without having to cut the drive shaft down, but I am not certain about that.
Old Sep 7, 2004 | 08:31 PM
sullyda1's Avatar
sullyda1
Thank you. I guess I'll have to get the case length. That should get me closer.
Old Sep 7, 2004 | 08:45 PM
fellro86's Avatar
fellro86
Fordlover2501970 just put one in behind his new 390, maybe he could cget the length for you. I think they are the same for length behind the block, just that they have the different bells. He has the short tail version in his. I used to have a couple extra, but don't anymore. The ones from the cars will work, but you will have to custom your driveshaft.
Old Sep 8, 2004 | 07:40 AM
jowilker's Avatar
jowilker
Dave, The answer to your question is yes. A C6 for a FE is a direct replacement for the FMX. Your 352 is a FE family engine. The two trannys are a different length so driveshaft replacement is likely part of the deal.
John
Old Sep 8, 2004 | 09:51 PM
sullyda1's Avatar
sullyda1
Jowilker, thank you very much. I can easily handle the drive shaft. Knowing the trans will exchange is great.
Old Jul 16, 2014 | 04:48 PM
camperspecial67's Avatar
camperspecial67
FMX vs C6
I now this is a 10 year old thread but on the chance that anyone is still reading it. How did that switch from the FMX to the C6 go? I am thinking of doing the same thing to my 67 camper special....
Old Jun 16, 2020 | 01:04 PM
TylorB's Avatar
TylorB
Also doing this swap in the next 2 weeks or so...
I am doing the FMX to C6 swap here next week any pointers or help would be greatly appreciated, I have never done anything like this before but I am a heavy machine and tractor mechanic so I should be able to do this. Will try to document and make notes for future reference... Thanks in advance...
andrew's64
Aug 6, 2016 05:50 PM
Rollin'in'79
Jul 29, 2016 02:32 AM
cr500monster
May 4, 2013 03:16 PM
fastredford
13
May 4, 2010 08:33 PM
1966_F100
Mar 22, 2010 07:31 AM
