Adding trailer brakes
Old Sep 5, 2004 | 11:35 AM
victorcharlie's Avatar
victorcharlie
Planning to pull a 20' deep V hull inboard/outboard with my 84 F-250 2wd. My buddy has been pulling it with his F-150 and stopping it has caused him some concern. I'm set up for trailer brakes on the truck. I'd like to add trailer brakes to the trailer, just for piece of mind. Trailer has dual axles, anyone done this? App. cost? Can I back it into the water with the brakes plugged into the controller? Thank, VC
Old Sep 5, 2004 | 01:41 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I'm not sure but I think most boat trailers use a surge brake system because it's hydraulic instead of electric.
Denny
Old Sep 5, 2004 | 03:03 PM
Steina's Avatar
Steina
CO River Rat
VC -
If the trailer doesn't have brakes now, check to see if the axle spindles have brake mounting flanges - if not, you'll have to install new axles or have flanges put on.
If the trailer has surge brakes, do you want to change to electric brakes?
The electrical connector should always be disconnected before putting the trailer in the water, no matter what type of brakes you've got.
Steve
Old Sep 5, 2004 | 04:25 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I would look into doing surge brakes instead of electric brakes. You can buy a surge brake/coupler unit to go on your tongue and axles with hydraulic brakes at trailer parts supply shops or ask a local boat builder where to get ahold of some locally.
Try www.etrailerpart.com
Old Sep 6, 2004 | 06:55 AM
jowilker's Avatar
jowilker
Charlie, I wouldn't do anything, your truck should stop the tow fine. Problem with adding brakes ito a boat trailer is making them go snorkling all of the time.
That aint good.
John
Old Sep 6, 2004 | 10:03 AM
Steina's Avatar
Steina
CO River Rat
VC -
Most states have a requirement for brakes if the boat/trailer rig is over 3000 pounds (your rig is probably in the 4500-5500 range). Not sure about Utah, but even if they're not required brakes would make your tows a lot safer. Also, some states require the tow vehicle to have the capability of applying the trailer brakes, making surge brakes illegal. I installed Fulton electric brakes on my boat trailer; they're made for marine use with powder-coating, SS springs, etc. Been on there 3 years and no corrosion problems yet.
Steve
Old Sep 6, 2004 | 11:28 AM
Steina's Avatar
Steina
CO River Rat
VC -
Looks like Utah's requirement is - at 20 mph your tow vehicle/trailer has to be able to stop within 40 feet. If it can't, you need trailer brakes.
Steve
Old Sep 9, 2004 | 05:47 AM
blackf3504dr's Avatar
blackf3504dr
VC , to answer your question I have done a few ( worked for an RV dealer ) .The brakes run about $100 per axle , If your axles are set up to have brakes you shoud be able to bolt on and wire a set in an hour . You will only need to put them on one axle .
Old Sep 19, 2004 | 03:05 AM
Loan Ranger's Avatar
Loan Ranger
VC, I know a man who is a fishing guide and a tournament fisherman. He will tow with nothing but a Ford. Since he fishes in tournaments in several states--including states where surge brakes are illegal--he has always used electric brakes. He was replacing the magnets, etc. about twice a year! He purchased a Fulton SS Marine electric brake system four years ago and it is still as good as new!
Irregardless of the brake system utilitzed, one should ALWAYS disconnect the trailer connector before backing down the boat ramp.
Along the lines of keeping moisture out of electrical connections and assemblies, Star Brite out of Ft. Lauderdale, Florida makes a liquid electrical tape to brush on electrical connections. Brush it on and wait five minutes and you have connections impervious to water, heat, humidity, and cold. It is really awesome stuff! I do quite a bit of vehicle wiring and I use it on every harness, etc., that I build. In all the time I have used it, I have NEVER had a connection damaged by dirt and dust, water, heat, or vibration. That even includes use on farm equipment!
PlimptonJr
24
May 7, 2013 11:41 PM
Shepardsonp
6.7L Power Stroke Diesel
Mar 29, 2011 08:25 PM
DrSwinestein
Aug 22, 2010 04:38 PM
jhand124
80
Jul 6, 2010 08:54 AM
NoBite
All Things Towing
22
Sep 24, 2007 06:56 AM
