Sparkplugs
Old Aug 15, 2004 | 04:36 PM
prisonbossa's Avatar
prisonbossa
Sparkplugs
Hi all ,I have a 1996 Ford Explorer , 4.0L , use mostly for town driving with the odd highway trip. I went to buy Boch plugs and the parts guy said don't use them they will burn out your catalytic converter. Any suggestions for a good plug for this truck. thanks
Old Aug 15, 2004 | 07:32 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
Your truck has an EDIS ignition sytem which is based on a "waste spark" design. Hence, it needs a good double platinum plug. In this regard, Motorcraft and Autolite DP's are the only way to go. They are OEM replacement plugs, and they work the best.
Motorcraft has also designed a "finewire platinum" plug which is supposedly even better for EDIS, offering more platinum where it's needed in order to reduce fouling and requiring less firing voltage (hence less stress on the system). So if you run across these plugs (FM series) they should work just fine, too.
97powerstrokemaniac
Feb 11, 2013 04:01 AM
alvald83
Oct 5, 2012 11:35 PM
lilmustangboy
2004 - 2008 F150
Apr 4, 2010 11:54 PM
zinkcalls
Dec 23, 2008 04:01 PM
garysorenson
31
Jul 19, 2008 11:23 PM
