Here are the specs for my next upgrade to the 396FE:
Bore 4.08
stroke 3.784
CR 10.68
EdelHeads KC stage II
Victor intake
1000cfm carb
Crane 521 cam
DD2K is giving me approx. 600HP and 550tq.
Can someone confirm my numbers. I am nopt real confident with DD2K. yet. I couldn't find LCA for the 521 so I used 108 for both fields.
I can already yell you that you're gonna get a lot of responses to step up to the bigger Crane 541 cam. Or, an even bigger custom grind.
I like the 521 for my truck that will still be used as a truck. But for a track toy with the weight savings you have planned, the victor intake, a 1000 CFM carb, and the Stage II heads, you need more cam!
I agree that with headers with 2"+ primaries, running open, that you should approach 600HP, maybe just a tiny bit less. I think that there would be more to be had if you increased your compression substantially and ran a little bigger (not much) solid roller. Comp has a cam #33-781-8 that has 292/292adv,248/248@.050, .645 on a 110cl that should make that combination of yours absolutely fly with about 11.5-12.0 compression and premium fuel. It would give great mid range, and top out at around 6500. It is the cam I am going to put in mine to bring back a little more mid range.
Brian,
I am not ready to change out the pistons just yet. I can get to 10.68 by changing to a different headgasket. Maybe 11.00 if I mill the head some.
The adv. dur of the 541 is 301/305 at .632/.655 lift. I don't know the CL can some one tell me?
That is bigger than your description above. Did I miss something?
Russ I ran it with large tube headers and muffs. 7500rpm is too high. I want to shift at 6500 redline at 7000rpm The person reding the graph for me gave a lower peak rpm. I will have to run it again.
Greg,
The 2.19 int and 1.75ext. valves won't fit in a 3.08 bore. At least I don't think they will. Yes the truck is on a serious diet and weight transfer program. The cab and engine are moved back 6". As for stall I was thinking of 3200-3500rpm. With 4.11 or 4.56 gears and 31"x16" tires on 16" rims.
Keep in mind that the hydraulic rollers have a MUCH slower ramp than the solid rollers. This means that for any given advertised duration there is less "area under the curve". Without doing alot of comparison, it is likely that a roller with an advertised duration in the 280's may outflow a hydraulic with an adv duration of 300. Don't bother to correct me if I missed it a little, I'm just making a point. This means that you can have the performance of a large hydraulic without some of the bad side effects like loss of compression, vacuum, reversion, etc...
Randy, I'am going to run those # again also...I knew that the HP was to high..I dont know what I did wrong...And remember I think it for every .006" you mill the head you het approx... .1 on the CR....So I have been told, A rule of thumb thing?
And what you take off the heads you should take off the intake so the ports match..
And I also agree, I think a 31" tire is about right for out trucks....I'am going to run the Nitto 404s on the back of mine, but in a 305/60/R17 that will give me 12."5 of rubber per side! With ION 138 style wheels all the way around...
And then for Occational Drag strip runs...there's a wheel house that make's a custom 8 lug 15" rim for mounting slicks on.... Cant wait Randy to see more Pics of your project...
From Keith Craft's website: "We have found the standard 390/ 428 blocks will try to split when run in excess of 600HP"
He sells a main girdle for addressing this, but it sounds like you want to leave the bottom end as is. Not sure if this matters to you or not, but it seems like something you may want to consider as you approach 600 hp (on DD).
Brian, I will try the cam you suggested in DD.
Russ, That did help.
Bob, A main girdle is definitly a good suggestion.
Thanks for all the great feedback everyone.
