Computer Chips & Tuners
Programming my EEC
Old Dec 20, 2003 | 04:40 PM
521_Ford's Avatar
521_Ford
Programming my EEC
Can anyone suggest to me what tuner to use on my EEC-IV? I have a 1995 F-250 with a tired stock 460 that is getting a 521 long block replacement. I'm told I will have to make some changes to the EEC. Also, anyone have any ideas where I can find the EEC on the truck. Is it the 5" x 7" silver box under the dash center/driversideish. it has a small plug on the drivers side, and a place to plug a plug in, (empty) on the passenger side.
521_Ford
Old Dec 21, 2003 | 04:42 PM
521_Ford's Avatar
521_Ford
Well I've learned so far there is no programmer for a 1995 F-250. The Truck has DOE0 computer code. Diablo makes a Delta chip that appears they will custom program for a DOE0. OH, and I found the EEC, it passes through the firewall at the drivers side kick panel. the DOE0 code is a sticker on the outside of the metal case.
Can anyone add to this, thanks?
521_Ford
Old Dec 21, 2003 | 07:09 PM
Blurry94's Avatar
Blurry94
SCT (Superchips Custom Tuning) makes several variations of tuning software and will work with just about any EEC IV ECM. It's a little pricy, but from what I've read, it's the best tuning software on the market right now.
Old Dec 21, 2003 | 09:11 PM
521_Ford's Avatar
521_Ford
Hey Blurry, I can only find tuning for 96 and newer, am I missing something?
Thanks,
521_Ford
Old Dec 21, 2003 | 10:22 PM
FTE Ken's Avatar
FTE Ken
Actually, the Diablo Revolution tunes far more parameters than the Superchips Custom. Costs a little more, but just like with the Predator.... you get more.
Both products can be used for burning a chip. Neither is end user software.
If you need to purchase a chip you should go with Diablo because Superchips has dropped all EEC-IV support.
Old Dec 21, 2003 | 10:38 PM
521_Ford's Avatar
521_Ford
Hey Ken, I've stroked and bored my 460 to a 521, added a 262 comp cam. the crank is zero ground, and the timing set is going to be pre 73. Because I live in CA, I'm using the Banks Exhaust, stock intake, stock fuel injection. My question is do you think with the stock settings in the ECM will run the engine? I'm looking at ordering a One stage diablo sport chip and order a custom program. If the stock ECM settings will run the engine, I'm thinking then it will pass smog. I'd have stock (smog day) setting, then a custom tuned setting. The computer code is a DOE0.
I will take delivery of the 521 long block mid January. The truck still has the tired stock 1995 460 in it.
521_Ford
Old Dec 21, 2003 | 10:47 PM
FTE Ken's Avatar
FTE Ken
No, the stock computer won't work with it. It may run but it will run like crap, and dangerously lean. The cam makes it even worse.
Old Dec 21, 2003 | 10:51 PM
521_Ford's Avatar
521_Ford
Ken, What would you suggest? purchasing a 3 stage chip? and having 2 custom programs written? One to run it economically, and the other power?
Old Dec 21, 2003 | 11:54 PM
Blurry94's Avatar
Blurry94
Ken...when did they say they were droping EEC V support? I was looking at this; and they're showing that they have support for EEC IV & V with thier software available for individual users.
Old Dec 21, 2003 | 11:57 PM
Blurry94's Avatar
Blurry94
Thanks,
521_Ford
You might be mistaking this for a Microtuner, which it's not.
Old Dec 22, 2003 | 12:03 AM
FTE Ken's Avatar
FTE Ken
Superchips no longer supports EEC-IV. Superchips Custom is a completely different product, from a different company, that is licensed by Superchips, not aimed at the average end user. Superchips only provides existing EEC-IV tune files and is not creating new files. This has been posted on their BBS for a long time.
Old Dec 22, 2003 | 10:12 AM
Thunderbolt's Avatar
Thunderbolt
521_Ford
Hi 521. San Diego is the home front here. Are you in Cali? I am working on the same sort of project. My build is a 557 based on 460 with 292 cam. I am looking at using a 1996 Cali EEC V SFI controls to get by the cam and VE problems. No total success yet but have learned alot and received hundredes of E-mails looking for chips, total tuners and data on BBF's with EEC control. I have managed to get all the computer data out of the EEC and on my laptop where we can start tearing the code apart and modifying it. There is plenty of room in there to change stuff, 3 empty banks. I will keep you informed on our progress if we crack the code, and we will. Might be a market here. With the strong request we might field this cheap setup if we can master the code, and the code looks fairly simple. We used a basic stamp interface. We could sell this and the rom moder for about 50$. Way cheaper than all the other stuff out there and you can do it all yourself. No sending stuff back in for mods. You build, You mod, You race. No middleman.
P.S. We should be able to pass emissions with this setup when done. Will let you know after some dyno pulls.
Scott
Old Dec 22, 2003 | 10:22 AM
FTE Ken's Avatar
FTE Ken
When did you start sponsoring this site? You're welcome to ask questions, and discuss things... but do not use this site to discuss your potential market and marketing opportunities unless you're an advertiser here.
Old Dec 22, 2003 | 10:26 AM
Thunderbolt
I thought this was where people came to get help on EEC stuff. He is in the same perdicament I am, so I offered some help.
Old Dec 22, 2003 | 10:27 AM
FTE Ken's Avatar
FTE Ken
Read the edit I made while you were posting. Please do not use this site to discuss your potential markets.
I'll be happy to program a chip for his application.
