Oxygen Sensors
Old Jul 31, 2004 | 08:16 PM
websthes's Avatar
websthes
Oxygen Sensors
where are they? what do they do
my friend says they're expensive but that his mechanice gave him a trick to clean and fix them up
Old Jul 31, 2004 | 08:26 PM
EPNCSU2006's Avatar
EPNCSU2006
In the exhaust stream, their positioning varies depending on what vehicle we are talking about. The computer uses the O2 sensor(s) to trim the air/fuel ratio.
Old Aug 2, 2004 | 09:29 AM
beastybronco's Avatar
beastybronco
they are not that too expensive ... around $50 at autozone i believe atleast for my model
if u have a trick to clean them please share
Old Aug 2, 2004 | 05:31 PM
websthes's Avatar
websthes
ima gonna ask him... something about just putting them in a coffee can with something or other is supposed to clean them... but i hear they're tough to get out
mine is a '90 f150 with a 302, auto. after i've been driving for an hour the check engine light goes on. i used the code reader and got code 41 from the computer memory
Old Aug 3, 2004 | 08:17 AM
beastybronco
i dont know what the code means im sure someone does but i know that you can rent a O2 sensor socket and tool from autozone or other parts stores also if u run the vehicle till the exhaust pipe gets hot that will make it come out easier and there is always penetrating oil also (just be careful with flamable stuff on hot exhaust pipes!)
and if u can find out what u clean them with i know that the inside has two platnuim strips and the outside is ceramic so i have no idea what can clean the combination without messing it up
Old Aug 3, 2004 | 11:36 AM
jerrybro's Avatar
jerrybro
41 means the right bank is running lean.
Old Aug 3, 2004 | 12:08 PM
Phinxter's Avatar
Phinxter
I just needed to mention that if you have a O2 after the cat its for monitoring the cat efficiency only, has nothing to do with A/F mix.
Old Aug 3, 2004 | 12:51 PM
beastybronco
good to know...that makes sense
thanx phinxter
Old Oct 7, 2006 | 06:21 AM
coralbayy's Avatar
coralbayy
oxygen sensors
I have a 98 f150 triton v8 4.6. My truck needs new oxygen sensors anyone know how many this truck needs. How expensive are they?
Thanks
Coralbayy
Old Oct 7, 2006 | 08:33 AM
Phinxter's Avatar
Phinxter
Thanks
Coralbayy
How do you know you need new O2 sensors? For the Bosch about $50 but they don't last very long, for OEM about $110, you have 4
Old Oct 7, 2006 | 02:24 PM
EPNCSU2006's Avatar
EPNCSU2006
OEM O2 sensors are made by Bosch....
Old Oct 8, 2006 | 08:09 PM
TigerDan's Avatar
TigerDan
Hi coralbayy and Welcome to FTE! Please take a moment to check out the Guidelines as they contain important info that you'll need when posting on the site:
https://www.ford-trucks.com/guidelines.html
I'm seeing prices of about 46 bucks for the Bosch up to around 65 for other brands.
Diesel_Brad
90
May 27, 2025 06:34 PM
rednekrailroader
General Automotive Discussion
28
May 4, 2006 03:13 PM
fordflaresides
Jul 28, 2004 10:42 AM
Mil1ion
15
Sep 17, 2002 02:21 PM
