no power switch
Old Jul 17, 2004 | 05:04 PM
hermangarza's Avatar
hermangarza
no power switch
i was wondering if it was possible to put a flip switch some where under the dash so even if u have the key the truck wont turn on. i was looking at my trusty haynes book maybe if i put inline the run wire? i have a 1981 f-100 with duraspark II.Any ideas?
thanks
Old Jul 17, 2004 | 08:24 PM
Franklin2's Avatar
Franklin2
If you have an automatic, you could find the red/blue wire coming off the ignition switch on top of the steering column under the dash, and cut it and run it through a switch. This won't let the starter turn over. I guess if you have a manually tranny someone could still roll it down the hill and pop the clutch though.
Old Jul 17, 2004 | 11:27 PM
hermangarza
ill look for it tommarrow morning but if the switch is off and they try turn on the truck damage, won't occur to the other componets?
Old Jul 18, 2004 | 11:51 AM
hermangarza
found a blue wire with red line on it, im guessing i got the wrong on as it still turned on even if the wire was broken.
Old Jul 18, 2004 | 05:04 PM
Franklin2's Avatar
Franklin2
If that wire is broken, no damage will occur. If they leave everything on, and you come by later, the battery may be dead, but what will happen is the starter won't turn over if the switch is flipped. If they want to really get your truck, they could go out and jump across the starter relay, but you can prevent this by locking the hood. Ford had a remote underdash lock for the hood. My 1980 has one.
The wire you found is probably a dash illumination wire. You said it was blue/red. What you need to find is a red/blue. The first color listed is the main color of the wire, and the second color is the stripe or hash marks. If you go out and look at your starter relay, it will have this same color wire on it, because that's where it eventually ends up after going through the neutral start switch on the tranny.
Old Jul 18, 2004 | 10:39 PM
hermangarza
saw it now but its a bit tricky to be able to cut it and run a switch. would i have to remove any thing to get a better view?
joshua6430
26
Feb 13, 2017 12:54 AM
Rell
May 25, 2016 10:14 AM
Jageesey1
Dec 23, 2015 03:08 PM
88f1504x4
Feb 9, 2014 04:20 PM
Bullmax
Apr 5, 2004 07:34 PM
