[updated:LAST EDITED ON 12-Jun-02 AT 06:10 PM (EST)]>What do you mean its not hooked up on this year
>Explorer(2000)4.o
bigred22769 are you also richam? Richam posted no information regarding his Explorer. In '95 Ford put a standard OBD-II type connector under the steering wheel however it didn't go active until the '96 model year. On a 2000 the OBD-II port is active. If yours also isn't working then there is a problem either with your scanner or your port. My bet would be on the scanner though.
