OBD-II port doesn't work, no power???
Hey guys,
I just bought a 2002 F250 7.3L and for some reason I'm not getting any power through my OBD-II port under my driverside dash. I've tried plugging in a new programmer and a OBD-II code puller and neither power-on. Is there a fuse for the OBD-II port? Maybe there is a loose connection to the computer itself? I haven't dug into it yet but I figured this would be a great place to start. Thanks alot. Oh yeah.... My check engine light in on.
Thanks in advance!
Thanks in advance!
Alan, (kind of on topic) I just posted in the Sport Trac forum. I am having same problem trying to connect my AE to a friend's 02 Sport Trac. I told him I could pull his codes but AE will not see the connection to the port. Plug into my truck and all is fine. Am I looking for a blown fuse? Does the OBD port power the AE? BTW, switched to OBD compliant in setup before trying to connect to Sport Trac.
No, running off battery. I know it's something in the Sport Trac because AE works fine on my truck, which is right next to the Sport Trac. I did find out in Sport Trac forum that it is fuse 17, and, like Alan said, it powers OBD II and cigar lighter. I'll check it in the morning. If fuse is ok, does anyone have any other suggestions?
Again, disconnect the port or retry the setup. The setup was my problem with my truck. Multiple tries and got it.
XFORMR
12-08-2015 07:33 AM
gamehunter
17
09-07-2002 07:47 AM
