Sponsored by: Auxito
spark knock again
Old Jun 19, 2016 | 09:06 PM
shooter123's Avatar
shooter123
spark knock again
had it before, code p1401. changed out dpfe and it worked for 6 months. now spark knock again. now though I have no codes though. no vacuum leaks that I can find. new egr from before I had the problem. I applied vacuum to the green hose and it stumbled so the ports should be ok. anytime I go above 3000 rpm i get the pinging. I replaced the dpfe again and no difference.
Old Jun 19, 2016 | 11:42 PM
Bluegrass 7's Avatar
Bluegrass 7
Your mixing up old history trying to find the present issue.
Can't do that especially with no code.
I would say either clean the EVR or replace it.
It may be holding the EGR open a bit, when it should be closed.
The EVR is a 3 port device. It passes vacuum to the EGR and vents it to atmosphere when closing the EGR.
It has nothing to do with blocked ports behind the EGR..
This malfunction will be cause for spark knock.
There is no code for this malfunction.
Your hearing it is enough.
Good luck.
Old Jun 20, 2016 | 12:13 PM
shooter123's Avatar
shooter123
will try that later today and post the results, thank you.
Old Jun 20, 2016 | 02:45 PM
shooter123's Avatar
shooter123
well, shoot, when I wrap her up to 5 grand it still does it................................................ ....................................Just kidding man. Bluegrass, thanks man I replaced the evr and no more spark knock. Oreillys even took back the dpfe I bought. Again thanks for the help, it is truly appreciated.
angela1881
Bronco II
17
Feb 13, 2014 10:46 AM
Shanemh
Apr 27, 2010 03:37 PM
rochs77
1983 - 2012 Ranger & B-Series
May 29, 2007 09:34 AM
brandon0011
1997 - 2003 F150
Feb 25, 2007 11:13 PM
riverrats007
Dec 12, 2005 10:50 PM
