Code reader port not working ????
Old Jun 9, 2002 | 12:37 PM
richam's Avatar
richam
Anyone got any Ideas on why my code port doesnt work
cant pull codes because of this,Have bad miss and stalls out
alot.
Old Jun 12, 2002 | 12:27 PM
reberhardt's Avatar
reberhardt
It's because for your year Explorer the diagnostics port wasn't hooked up.
Old Jun 12, 2002 | 02:30 PM
bigred22769's Avatar
bigred22769
What do you mean its not hooked up on this year Explorer(2000)4.o
Old Jun 12, 2002 | 03:28 PM
FortyFords's Avatar
FortyFords
What type of code reader are you using I hope its a OBD-II and not
OBD-I
The later cars trucks from 96 an up use OBD-II
Rich
Ford Trucks Built Tough!
Not like all the rest!
Old Jun 12, 2002 | 05:09 PM
reberhardt's Avatar
reberhardt
[updated:LAST EDITED ON 12-Jun-02 AT 06:10 PM (EST)]>What do you mean its not hooked up on this year
>Explorer(2000)4.o
bigred22769 are you also richam? Richam posted no information regarding his Explorer. In '95 Ford put a standard OBD-II type connector under the steering wheel however it didn't go active until the '96 model year. On a 2000 the OBD-II port is active. If yours also isn't working then there is a problem either with your scanner or your port. My bet would be on the scanner though.
Old Jun 12, 2002 | 05:23 PM
michaelskerrett's Avatar
michaelskerrett
Post Code reader port not working ????
shooter123
1997 - 2003 F150
Jun 20, 2016 02:45 PM
Franko72
Mar 12, 2013 12:44 PM
ALL AMERICAN BOY
Electrical Systems/Wiring
Feb 8, 2012 06:22 PM
tagunderson
Mar 9, 2008 09:24 AM
santacruzf250
Jul 1, 2007 08:40 PM
