Data Link Connector Question
Old Feb 8, 2012 | 03:28 AM
ALL AMERICAN BOY's Avatar
ALL AMERICAN BOY
fordie's
when i plug in code scanner nothing happens.
i looked in DLC and it looks like it has 'tab' contacts.
my code scanner has little pins like serial and parallel
port connectors on pc.
it's a '99 4.6
how's this going to work?
Have A Nice Day!
Old Feb 8, 2012 | 06:54 AM
JWA's Avatar
JWA
Have you checked the cabin fuse box yet? There is a fuse for the DLC which often shares the power port or cigar lighter outlets. Check position #23 which should be a 20a fuse.
What model scanner/reader do you have? They should be somewhat universal connection-wise, fitting any vehicle with OBD-I or OBD-II
Old Feb 8, 2012 | 08:03 AM
subford's Avatar
subford
There should be another cable that connects the scanner pins to the DLC.
You should have about four cables that have different ends on one end and the other end will all be the same that goes into your scanner. You need to pick the cable that matches your DLC.
Old Feb 8, 2012 | 01:00 PM
ALL AMERICAN BOY
jwa
thanks!
i've got the little owner's manual.
i looked up fuses & breakers that said DLC.
i think one was those smaller breakers down
middle row. i'll check them.
Have A Nice Day!
Old Feb 8, 2012 | 01:06 PM
ALL AMERICAN BOY
jwa
it's an Innova 3030.
subford
zero adapters with it.
the $250 innova has 3 or 4 colored adapters.
i'm no expert on this, but they look like their
for testing other components.
i can post link to exact model.
i'll double check what i'm calling 'tabs' in car connector.
innova ABSOLUTELY has small brass computer-like pins.
outside plastic shape is a match.
that v-type shape w/2 rows connectors.
Have A Nice Day!
Old Feb 8, 2012 | 02:10 PM
subford's Avatar
subford
An Innova 3030 only cost about $50.00.
http://www.amazon.com/Equus-3030-Inn...8731634&sr=1-1
I do not know what you have that cost $250.00
Maybe a 3130 without the cable, they are about $130.00?
Amazon.com: Equus 3130 Innova Diagnostic Code Scanner with Live, Record and Playback Data Capability for OBDII Vehicles: Automotive
Old Feb 8, 2012 | 03:33 PM
ALL AMERICAN BOY
subford
here's the better one with extra adapter's.
Equus 3140 Scanner - Walmart.com
any of these extra adapter's look familiar?
i'm going to look at vehicle for OBD II sticker
Have A Nice Day!
Old Feb 8, 2012 | 03:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The model 3030 will not read the 6.0 OBD output. You need minimum the 3130. It says it reads OBDII plus CAN. If yours does not say CAN capable it won't read your truck.
OOPS. just checked your truck year/model. Your 3030 SHOULD read your truck..... Sorry, I thought I was still in the 6.0 forum.....
Old Feb 8, 2012 | 04:48 PM
subford's Avatar
subford
Originally Posted by ALL AMERICAN BOY
subford
Have A Nice Day!
The Blue adapter is the one for your truck.
Old Feb 8, 2012 | 06:22 PM
ALL AMERICAN BOY
jva
fuse #23 was the culprit!
i pulled the cig lighter heavy lead BEFORE
putting new fuse in.
i gangstered fuse from 'fuel door' for now, it was handy!
Have A Nice Day!
2 cowpokes
Oct 15, 2013 05:33 AM
sun622
Escape & Escape Hybrid
Jul 8, 2011 06:58 AM
Reefmonster
Jan 9, 2010 12:15 PM
pyramid
1983 - 2012 Ranger & B-Series
Jul 26, 2008 12:49 PM
abeltre99
Mar 21, 2007 06:15 AM
