Sponsored by: Real Truck
7 Pin light plug ?
Old Jul 25, 2004 | 08:45 AM
  #46
RED-STROKE's Avatar
RED-STROKE
Really easy...pull the relay out of the socket and use a test light to determine which contact has 12v power only when the vehicle is shifted in reverse. This will be the contact that trips the relay, and the one that you will want to tap into with your switch.
Old Jul 25, 2004 | 11:07 AM
  #47
rmilchman's Avatar
rmilchman
Make sure the wiring you use is the same gauge as the wire you are tapping. Depending on how Ford wired everything, this wire may need to cary the load of the built in reverse lights.
Old Jul 26, 2004 | 08:06 AM
  #48
RED-STROKE's Avatar
RED-STROKE
Good advice!
mustangman
May 28, 2012 06:03 PM
secolvin
All Things Towing
Sep 28, 2011 04:00 PM
warriorm
Aug 26, 2010 08:41 PM
Wrecker
Electrical Systems/Wiring
Mar 26, 2007 07:32 AM
FarmLaw
Garage & Workshop
May 8, 2006 01:18 PM
