Towing package trailer wiring question
Old Mar 25, 2007 | 08:35 PM
Wrecker's Avatar
Wrecker
I just bought a 1996 F150 with the Trailer towing package. There are 2 round plugs in the back for hooking up a trailer. One plug has 4 male pins, the other has 3 male pins. I assume the 4 pin is for lights, the 3 pin for electric brakes. My question is...is there an adaptor to hook these plugs up to a 4 pin flat connector (thats what is on my trailer) for the lights? If not, where can I get the correct female plugs that will fit the one's on the truck? Also, my 1967 trailer has electric brakes that work with mercurey switches mounted on the trailer tongue. They do require 1 hot wire and a ground. They have a flat 2 wire connector. Will I need to put in a brake controller in the cab to get power to the trailer brakes? Any help is greatly appreciated!
Old Mar 25, 2007 | 10:36 PM
Mil1ion's Avatar
Mil1ion
You mean like this ?
Old Mar 26, 2007 | 12:35 AM
Steina's Avatar
Steina
CO River Rat
Paul -
If those mercury switches sense trailer deceleration and send 12v to the brakes, then you don't need an in-cab brake controller. Sounds like trailer braking would be "full on" with no modulation when the TV slows down, so you might want to seriously consider replacing the switches with a controller. Also, if the trailer has no breakaway system, that should be added for safety.
Steve
Old Mar 26, 2007 | 07:32 AM
subford's Avatar
subford
The Battery charge wire will supply 12V to one of the plugs when the key is in the on position.
You can get a pig tail from a FORD dealer that will plug into those two plugs and has the flat and the large round trailer plugs with it.
Here are three diagrams of your trailer wiring.
http://i54.photobucket.com/albums/g9...96Trailer1.gif
http://i54.photobucket.com/albums/g9...96Trailer2.gif
http://i54.photobucket.com/albums/g9...96Trailer3.gif
mitsudave
1997 - 2003 F150
13
Oct 24, 2012 06:27 PM
glovemeister
26
Mar 13, 2012 08:21 PM
jonesn4fun
Electrical Systems/Wiring
Oct 24, 2011 07:06 PM
sherpa
All Things Towing
Jan 6, 2006 02:00 PM
Moonblink
All Things Towing
May 14, 2004 06:06 AM
