Sponsored by: Real Truck
Trailer wiring
Old Aug 26, 2010 | 07:06 PM
warriorm's Avatar
warriorm
Trailer wiring
It appears to me that the factory 7 pin trailer plug does not offer a hot 12V pin for aux lighting. My horse trailer uses the center pin for both back up lamps and interior lighting. Does anyone have an easy way to add a constant 12V to the factory center pin of the 7 pin jack?
Old Aug 26, 2010 | 08:13 PM
mrford60's Avatar
mrford60
look in your owners manual or a wiring diagram for your year truck but i am sure that there is a 12v hot wire in the plug but it is only hot with the key on. the diagram i have says it is an orange wire but that may be an early superduty. i dont know what pin it is.
Old Aug 26, 2010 | 08:30 PM
TexasRebel's Avatar
TexasRebel
You can't really use that center pin for two different functions.
Old Aug 26, 2010 | 08:35 PM
sdetweil's Avatar
sdetweil
this page is REALLY helpful
I would guess someone fiddled with the TRAILER wiring. the center pin IS backup..
open the connector and move the wire over to the right pin..
and if the hot pin is not hot on Key on, then fix the fuse or relay..
Sam
Trailer Wiring Diagrams | etrailer.com
dchamberlain's Avatar
dchamberlain
This article shows the pins of the 7 way plug. The 12v pin is hot when the key is on. It is generally used to charge a battery on the trailer.
Edit: Too slow.
Old Aug 26, 2010 | 08:41 PM
sdetweil's Avatar
sdetweil
Edit: Too slow.
and internal lights..
Sam
talonpilot
2009 - 2014 F150
Feb 19, 2014 07:24 PM
secolvin
All Things Towing
Sep 28, 2011 04:00 PM
BURNSTOUGHFORD
1997 - 2003 F150
17
Oct 1, 2010 08:27 PM
Eric H
Jul 25, 2010 07:27 PM
07F150trucknut
Electrical Systems/Wiring
Jan 19, 2008 03:56 PM
