Annoying noise
Old Jul 6, 2004 | 02:54 PM
Labman's Avatar
Labman
Annoying noise
I am new to the site. I have just purchased a F-250 Crew cab FX4 6.0L. About two days after getting the truck I started to noticed a noise when turning left and only left. It sounds like a rubbing noise. Took the truck in to Ford and they said nothing was rubbing, and could not find any apparent damage parts. The mechanic did mention that he thought it might have something to due with the "hydrobooster", what ever that is. He mentioned that he had sent a post into the Ford message board and was waiting on ford to answer. This was a month ago.
Has anyone here had this problem and if so what IS IT??????? and How do I get it FIXED?????
The noise is very annoying, special when backing up trailers.
Thanks
Labman
Old Jul 6, 2004 | 02:55 PM
jdadamsjr's Avatar
jdadamsjr
How about recording it and posting it...
and also bringing it to another ford dealer that may be more willing to help !
Old Jul 6, 2004 | 03:01 PM
Labman's Avatar
Labman
I have taken it to two ford dealers. I can try and record it and post it.
Old Jul 6, 2004 | 03:05 PM
wolffee's Avatar
wolffee
hey how you doing i have the same problom and i brought it to my ford dealer and they put in my vin # and everything and it came back with a report check the thread about rear end clunk its not a rear end clunk its the front when taking lefts but thats the thread that talks all about it. ford knows about and says there is no fix and it should be atempted to be fixed
Old Jul 6, 2004 | 03:08 PM
wolffee's Avatar
wolffee
Here you go read this thread it talks all about it and i posted the exact print out that ford gave me stating all this check out the thread and let me know what you think...
https://www.ford-trucks.com/forums/s...d.php?t=255152
Old Jul 6, 2004 | 03:17 PM
Labman's Avatar
Labman
From what I read from your earlier post, everyone is getting a clunk sound. Mine is not a clunk but more of a rubbing sound. I do not feel anything different in the steering nor do I feel anything in the floor. I just hear the rubbing sound and it is annoying.
Old Jul 6, 2004 | 03:46 PM
wolffee's Avatar
wolffee
oh well i dont hear any rubbing mine is like a little thud under my left foot intermitenly on left turns from a reverse to drive . or somtimes after being drive for awhile and just making a left. sorry that didnt help thought it was similar problom.. let us know is you find anything or have anymore questions i dont think now its the same thing but who knows
Old Jul 6, 2004 | 06:35 PM
MotoraceD's Avatar
MotoraceD
the hydroboost is basically your brake master cylinder...mine leaked 2 day out.
Old Jul 6, 2004 | 07:14 PM
Hayapower!'s Avatar
Hayapower!
Thanks
Labman
Labman...
A/your hydro booster is the power unit for your brakes.. Instead of vacuum being used to 'assist' braking, hydraulic pressure from the power steering pump is supplied to the hydro booster for brake/pressure assist..
Is your noise 'constant' when holding the steering wheel into a 'left' turn..(without anymore turning) Or, does it make a rubbing sound as the wheel is turned.. Any chattering when turning, along with the noise?? in either direction..
Did your mechanic varify the noise?? Hear it himself.. And does it make the noise at all times..Cold/Hot?? Does it only have this condition when turning left with the brakes applied??
..............................HP.................. ................
Old Jul 6, 2004 | 07:29 PM
bighoss550's Avatar
bighoss550
also, does it make the noise when NOT moving? or just when the tires are rolling?
Old Jul 6, 2004 | 08:58 PM
wolffee's Avatar
wolffee
mine only makes the noise when i am moving. and i drive 45 miles each way and it makes a little clunk just as i turn in from work at home and i would say its nice and warm 75 on the highway for 45 min -50 min.i have no sound as the wheel is turning except the clunk all else is nice ans smooth. it is constant in the fact that you can preatty much plan on it doing it 80% of the time..i have sat in the drive way even tonight and got under the truck and grabed and shook every part i could see to check if it was loose. i took off the front driver wheel and chcked everything in there to make sure it was all nice and tight, no play more then normal in a 4wheel drive. it is defanantly only when tires are moving i have turned and rolled in the drive way over and over. any help or input is always great. thanks in advanced
Old Jul 7, 2004 | 08:27 AM
Labman's Avatar
Labman
I have not been able to hear the noise when sitting still, but as soon as I begin to move in a left turn I will start hearing the sound and it is mostly constant. At one time I thought it had something to due with brake calipers maybe sticking, but he mechanic did not think that was it. The mechanics have all heard the noise.
Old Jul 7, 2004 | 08:46 AM
wolffee's Avatar
wolffee
yup mine has heard it to ford has heard it and they say its a part of the engine and there should not be any atempts to fix but i dont my that. im sitll holding out for somthing to be uncovered.
Mike B.
Apr 11, 2012 03:17 PM
labman1014
Jul 26, 2011 10:15 PM
labman1014
Mar 22, 2011 08:53 PM
Shanemh
Jul 22, 2007 07:33 PM
supermanpsd
Mar 31, 2007 05:49 PM
