Grease points?
Old Jul 21, 2007 | 10:31 PM
Shanemh's Avatar
Shanemh
Grease points?
I have a annoying squeek, rubbing noise coming from under the front somewhere. The brakes are fine and look good. The guy I bought the truck from said he had it into Ford and they couldn't find anything. Twice! It doesn't happen all the time. Sometimes no noise at all, but there is no determine factor or condition when it decides to squeek. I noticed two grease nipples at front. What kind of grease is best to use, is there many more grease fittings to grease up whilst I am at it and any clue on the annoying noise!!!!!
Thanks, Shane
Old Jul 21, 2007 | 10:39 PM
Dean88's Avatar
Dean88
I always use red grease, because that's what my uncle (a truck driver) used on everything on his truck, and he easily will put 2 million miles on a truck.
I'm not sure if there are any more nipples, but check a chiltons/haynes manual, it will tell you if there are any more.
Old Jul 21, 2007 | 11:24 PM
lostin90s's Avatar
lostin90s
You should only have the ball joint fitting (Maybe) tie rod end ETC, u joints (maybe) Theses should cause no squeal what so ever.
If the bearing are good it may be you pads . I went though 6 set till I got a Ford set and the squealing and dust went away. They can be in good shape but the metal content may be off in mix . Good luck
Old Jul 21, 2007 | 11:31 PM
Dean88's Avatar
Dean88
You probably also need to grease your wheel bearings.
Old Jul 22, 2007 | 07:06 PM
t4kne's Avatar
t4kne
the squeak could be missing a bolt on a fender, loose door hinge, hood latch, seat, or any component that bolts to the frame that might be loose. They could all sound like under the truck. Does it only squeak over bumps or when brakeing or excelerating?
Note: I use a red grease that is a synthetic grease, I think Exxon makes it but I'm not sure, I got it at Autozone. I have have no problems with it.
Old Jul 22, 2007 | 07:33 PM
Shanemh's Avatar
Shanemh
The noise doesnt happen with bumps or braking, just when driving slow, like up to 20mph. Anything faster than that I cant hear because of driving noise.
Jimmy Dean
1997 - 2003 F150
Dec 19, 2007 10:17 PM
pebbles
Nov 17, 2006 11:05 AM
thullz
Nov 16, 2005 06:49 AM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
Oct 13, 2004 08:40 PM
97intimidator
1997 - 2003 F150
Jun 18, 2004 06:17 AM
