KW5413,
Not a problem, I appreciate all the advice and counsel I can get.
I ordered the truck to my specifications and took delivery in mid June 2004. The red sticker on the passenger side valve cover says 2004 engine. I believe that they reflashed the chip back in November of 2005 when the turbo was replaced. Are there more recent software updates?
I have the original metal pipe between the two blue plastic couplers on the hot side of the turbo and I understand that the replacement is plastic - not sure if the plastic is an upgrade or not?
Well, you have likely already read the best fixes for the blown turbo hoses. As a review this is what I would do:
With a course sand paper rough up the inside diameter of the Blue Hoses deep enough to cover the outside diameter of the metal tube.
Do the same with the O.D. of the metal tube.
Clean all contact surfaces with Brake Kleen
In some cases I have read that some folks have used a high temperature resistance silicone adhesive applied to both contact surfaces. Can't confirm the results.
Some have even drilled holes thru the clamp, sleeve, and pipe. Then used self tapping stainless sheet metal screws for a more permanent solution. I would caution that if you do this, remove the hoses after drilling and make sure there are no metal shavings. Then replace. Note: aligning all the holes may prove difficult so patience and planning is paramount to success.
Tighten clamps (my torque spec involves tightening her down 'til it feels just right then add an extra little twist).
These are all non - scientific or even technical solutions so go with whatever you feel is best.
kw5413,
Thanks - I now have gloves, sandpaper, spare blue turbo tubes, spare clamps and brake kleen on board at all times now. After you have done the turbo pipe reinsntall a few times it goes pretty fast.
Now in trying to track down the cause of my pipe blow off, in both main cases it only happened at high altitude +/- 6000 ft above sea level. I am wonderinng if boost can ramp up past the pressure threshold of the pipe & clamps if the EPB sensor is giving the computer the wrong barometric pressure? I will try to get the local dealer to check/replace the EPB and VGT sensor units.
Go get the new, upgraded blue hoses and clamps from the dealer. I had the same problem. Even had them replaced in '05, with supposed "upgraded" ones, but it still blew-off. Tried all the tricks (minus drilling) and kept blowing the tube off. I finally went to Pepboys and got some thick aluminum clamps and they worked. Well, I just recently (3 months ago) had my truck in for another oil leak, which by the way my trucks now been oil leak free for 3k miles (after 2 yrs., 15 visits and 9 leaks), thanks to a new, well trained, tech, but anyway. While I was in there for the oil leak the service adviser wrote down a laundry list of known problems with 6.0's. Mine wasn't necessarily having these problems, the SA just wanted them checked. I got the truck back with the new hose and clamps, and the tech was even nice enough to remove and return my aftermarket clamps, and not only have I not had them blow-off again, but there's also absolutely zero oil seepage through the new ones. So whatever they did with this newest version of the hose and clamp, it's working.
My dealer finally put a screw through the upper hose clamp into the turbo manifold after sanding, scraping, cleaning, etc. Also had the EGR and EBP sensor replaced, if that helped. The screw held it during my last trip, but the turbo was still winding up and down with no rhyme or reason, on a hill or flat. They fixed the problem but not the cause. After 3 blow offs (and 3 for the previous owner), they said the turbo was still within spec and they refused to replace or service it. This was after the regional tech did a full analysis. Since I only owned the truck for two months, the agreed to let me trade it for full value on a an 05. That's all in another thread I posted. The 04 had all recalls and the latest flash. I get to finally do a test pull on my 5'ver this weekend. All my toes and fingers are crossed.
I have the new thicker blue pipe (angled upper one) and the old clamp and it held fine on a 1000 mile trip hauling a car trailer with a car - highest altitude was 4150 ft above sea level. I was careful not to romp on it - tried to keep it no higher than 2300 rpms and steady.
Just in case I am taking it to the dealer in the morning to check the EPB sensor before I try going over the sierras.
So maybe as EnviroCon says the new pipe is a good fix. So far So Good.
Do you have the part numbers for the updated parts they put on your truvk? That would help the rest of us get the new parts ourselves....
These are the parts I picked up for my 2004 (engine tag says it is a 2004 motor) 6.0;
Upper Blue hose :5C3Z-6C640-AA
Upper Clamps (two req'd) : 6C2Z-6K786-AA
Lower Blue Hose :6C3Z-6C640-B
Lower Clamps (two req'd) : 6C3Z-6K786-CA
The new upper hose it definately thicker and stiffer than the original one that came with the truck.
The new Lower hose has two stainless wire bands around it.
Upper Blue hose :5C3Z-6C640-AA Upper Clamps (two req'd) : 6C2Z-6K786-AA
These are the P/N's that are listed on the Repair Order. I think the P/N's are the same as before, I think they may have revised the part or just got a good batch in.
Since I was lazy and didn't go through the whole 2 years of thread........Is it just my blue tubes that have an internal groove that fits onto the ridge of the metal pipe? Seems that once I get the blue tube locked onto that ridge on the pipe and get the clamp positioned correctly over it I never have any problem and I pull 36psi boost at WOT and hold 30psi steady and (knock on wood) I've never had any problem.
The blue tubes (both old and new) have the grooves etc. and correct groove alignment and cleaned surfaces are critical for the clamps to hold the tubes to the turbo and connector pipe. The mystery for me has been that my pipes continued to blow off after installation/reinstalltion by four (4) separate Ford diesel techs from Idaho to California who all had to know about the critical alignment and clean connections - the difference so far (the last month) has been the new blue pipe which is thicker and stiffer than the old one seems to be holding. This is after repeated code dumps by Ford techs and checkups and a turbo replacement by certified ford diesel techs.
Just had everything re-checked today at my local Ford dealer and they say it all looks good - so I'm going Elk hunting and maybe I should knock on wood.
OK, I was lazy too, should all the clamps\fittings be cleaned and reinstalled? I had 1 blow off and asked the dealer to clean and check all and they said it all looked good. Even though they didn't clean all of the clamps.
Here I was trying to be a nice guy and save Ford some money by not having to repair my hood again. Silly me.
See Kw5413's list of fixes about 10 comments back - I think that all contact surfaces have to be clean to have any hope of holding.
Wow, I'm really lazy. Thanks for pointing that out, just about wore me out for the day looking back that far. Sometimes I amaze myself. duh Apparently even lazier than the idiots at the dealership that wouldn't even do that little bit.
