1997 expedition ABS light on???
Old Jun 15, 2004 | 11:06 AM
JDMONTY77's Avatar
JDMONTY77
My ABS light is on and I checked the fluid. It was a little low and kinda gray colored. I added some fluid but it did not turn off the light. My pads look good, so is there any other easy things to check before taking it to the dealer? I have 250,000 miles on this truck in case that helps.
Old Jun 15, 2004 | 02:10 PM
Phil056's Avatar
Phil056
You may want to try and reset the abs light by resetting the computer (disconnecting the negative battery cable for 1/2 hr or so). Re-connect and see after you start the truck if the abs light comes back on, if it doesn't try driving locally for a while and do stop and go's and see if it pops back on. Have you checked the rears? could they be low? I'm not sure if the abs light goes on if they are?
Good luck
Old Jun 15, 2004 | 03:07 PM
buzzard's Avatar
buzzard
Most likely a sensor is malfunctioning.
Old Jun 15, 2004 | 06:51 PM
99expyTN's Avatar
99expyTN
Look at thisthread concerning the rear speed sensor. My abs light was on and it turned out the rear speed sensor was the problem. A $20 part and 15 minutes to change it.
philip
Old Jun 19, 2004 | 09:39 PM
myankow's Avatar
myankow
Rear sensor in top of differential had chips(junk) on it and caused this problem. Cleaned, but Needed new sensor, common problem. easy to change. My dash ABS light came on after a few feet of movment of the truck. I jacked up front tire one at a time to simulate movement, trouble shot to rear - only one sensor - this was easy.
Old Jun 26, 2004 | 07:59 AM
JDMONTY77's Avatar
JDMONTY77
if your front wheel speed sensor wires are broken this will cause the ABS light. Free fix for me.
Old Jun 30, 2004 | 09:35 AM
rcarroll's Avatar
rcarroll
By far the most common fix seems to be the vehicle speed sensor on the differential.
around 20 bucks at your favorite ford dealer and 10 to 15 minutes to replace it. only 1 bolt. 3/8" I think.
R.
ReBilld
38
Jul 16, 2015 06:16 PM
jct112504
Jun 23, 2015 05:51 PM
Mike E.
Jun 23, 2013 04:16 AM
Ohio Ford Farm
1983 - 2012 Ranger & B-Series
Sep 20, 2009 08:30 PM
woody1003
Feb 1, 2008 12:01 PM
