Fuel Pump Gone?
Old Jun 7, 2004 | 09:32 PM
pizalm's Avatar
pizalm
Fuel Pump Gone?
Today i was running my truck (76 F-100 2wd 302) to see if it leaked any oil out of the valve covers with new gaskets. Then when I was confident it wasn't leaking i revved it up pretty good and heard a strange noise so I shut it off. So checked if any thing was leaking and there was some gas on the ground.
I didn't know where it was coming from so i fired it up again and it was coming out of the fuel pump. I checked the fuel lines and they were fine. So i started it up again and it was coming out of the top half pump. Any suggestions, can i rebuild it or seal it up and try it again or buy a new one?
Any Help would be appreciated. Thanx.
Old Jun 8, 2004 | 03:02 AM
Ford_Six's Avatar
Ford_Six
The old pumps are rebuildable, but the kits aren't available, so replacement is the only option.
Old Jun 8, 2004 | 03:31 PM
pizalm's Avatar
pizalm
If it's just a gasket could i just use silicone and seal it up? If not how can I tell if a used one I find is good or not and compatible with my engine? eg: can I use a fuel pump from another engine family?
Old Jun 8, 2004 | 04:33 PM
LxMan1's Avatar
LxMan1
The diaphram has busted, you need a new one. They are usually under $20. It will also pump gas into the crankcase, so replace the pump and check the oil for a gas smell. If there is any gas in the oil, change it asap!!!!
Old Jun 9, 2004 | 03:36 PM
pizalm's Avatar
pizalm
I bought a new pump the other night. How bad is the gas for the oil? and it only ran for about 30 seconds after the pump leaked if that matters.
ruschracing4
Mar 8, 2015 05:04 PM
woodtrucker
Mar 4, 2014 07:00 PM
coreymck
Nov 18, 2013 02:33 PM
'78F250351m
Sep 16, 2011 05:17 AM
Gregg C.
Dec 12, 2005 07:06 PM
