Fuel Leak Help!
Old Dec 5, 2005 | 07:38 AM
Gregg C.'s Avatar
Gregg C.
Fuel Leak Help!
I have a '95 Powerstroke which I started smelling a strong fuel odor. The V of the motor was full of fuel so I put a new fuel pump in. Problem solved. About a week later it started leaking fuel again. This time it seems to be coming from the drivers side, right next to the motor, above the tranny. It leaks more with the rear tank than it does with the front. Is there some type of valve for the tanks there? Because I haven't pressure washed it yet, and can't see back there to good, I can only make out what appears to be some connections for fuel lines? Is there something else I'm missing? Is there parts I should grab before I start yanking this thing apart? Any help would be greatly appreciated.
Old Dec 5, 2005 | 07:06 PM
BltFordTough's Avatar
BltFordTough
Greg, Do you see a long 2 or 3 inch silver tube that goes from the oil filter to the front of the engine? I have a leak coming from somewhere in that area it is dripping from that tube, im not sure what that tube is. I am trying to track it down but its really cold out.
Is your intake gallery dry now?
Old Dec 6, 2005 | 08:04 AM
Gregg C.'s Avatar
Gregg C.
Intake gallery is dry. As soon as it warms up, hopefully this weekend I will pressure wash it and see what I find. I'll let you know. I was just hoping someone had a similar problem and could let me know what was there? If it was just fuel line, connections, etc.
Old Dec 10, 2005 | 11:18 AM
BltFordTough
Any luck gregg?
I am going to try and take a look at it today, because its getting bad I smell diesel in the cab The fuel lines are right there im going to take a close look at them.
Old Dec 11, 2005 | 07:25 AM
1997F-350's Avatar
1997F-350
could be one of the lines goint to the back of the head or the fuel tank selector switch.. a little hard to understand your post, a pic is worth a million words on here. post more and i can help more.
Old Dec 11, 2005 | 07:26 AM
1997F-350's Avatar
1997F-350
that sounds like your oil cooler. if you need oring part numbers let me know.
Old Dec 11, 2005 | 01:20 PM
big green 250's Avatar
big green 250
Help! I'm in the same boat too. We just had a few days of freezing weather here would that have anything to do with it?
I have a very strong fuel smell and the area between the heads is wet?
And I seem to be using more fuel.
Old Dec 12, 2005 | 03:25 AM
TexasRoughneck's Avatar
TexasRoughneck
k maybe someone can tell me what my fuel leak is and what the part is called so i can get another on the RH side of the fuel filter housing the nut where the fuel regulator is there is some kind of sensor just behind it toward the back of the motor where a wire plugs into it, i have a small fuel leak there but i aint got a clue what its called with the wire off it dont leak but with the wire plugged into it , after the motor gets warmed up it starts to leak. any help would be greatly appreciated thanks Lance
Old Dec 12, 2005 | 11:26 AM
Gregg C.'s Avatar
Gregg C.
Thank You. 2 fuel lines go into a small block on the front drivers side of the engine right above the oil pan. Lines look very rusty. Do you know what this is?
Old Dec 12, 2005 | 07:06 PM
big green 250
I found my leak!!! It was the fuel presure switch it was dripping one large drip every one second at idle. (wonder what it was doing at speed) anyway the part is about 60 bucks from Ford (part # E8TZ-9S283-A).
bcaughhorn
Feb 13, 2015 07:31 PM
spikedog
Apr 11, 2014 11:22 AM
cleon159
Mar 17, 2011 06:04 PM
tivoklr
Jun 9, 2009 09:54 PM
TakeEm
Nov 8, 2005 08:53 PM
