Any problems?
Old May 21, 2004 | 06:05 PM
biggieou's Avatar
biggieou
Well I'm definately not going to be able to get the motor, so thats out of the question. I'm not real worried about it. The 302 will pull anything I need and if not my 300 in my 78 will.
Old May 22, 2004 | 10:04 AM
biggieou's Avatar
biggieou
Hey I was just thinking, my buddies 250 is 4x4, will that transmission still work for my 2wheel drive 150. Are the t-cases on those married or divorced?
Old May 22, 2004 | 10:28 AM
n578md's Avatar
n578md
No, those transmissions are not the same. The 4x4 version has a deeper oil pan and a different filter (not a big deal, just something to remember when you're buying a filter for it.) and a shorter tailshaft. The Transfer case is bolted to the transmission directly on a 4x4, so it doesn't have the long tailshaft and housing there. I don't know if you can just take off the t-case on the new transmission and just replace it with your old transmission's long tailshaft housing and tailshaft. That may involve opening the transmission, I don't know. Maybe you could just leave the transfer case on it and just leave it in 2H mode. You'll have to see if the face to yoke dimensions are close enough so that you don't need a new driveshaft. That way you'll be one step closer if you want to convert your truck to 4WD. And also, if you mount the controls, the lever for manual shift or the switch and wiring for ESOF, you'll have a 2WD truck with a 2 WD Hi and 2 WD Lo! That would be pretty cool. My truck has a removable access plate on the transmission tunnel that I could remove to install the 4WD manual shifter and dust boot, I think your truck might be the same.
Old May 22, 2004 | 10:40 AM
biggieou's Avatar
biggieou
Yea I was hoping I could just drop the T-case off of it. Hopefully I can just get the tcase off and use my tail shaft and driveshaft.
92Ranger123
1983 - 2012 Ranger & B-Series
May 22, 2014 10:34 AM
NHWatchDog
1978 - 1996 Big Bronco
Dec 23, 2011 09:09 PM
coolen
20
Oct 17, 2008 08:35 AM
jack88
Apr 9, 2004 09:12 PM
roscoe
Nov 13, 2001 09:40 PM
