Oil & Lubrication
Rear Diff Fluid
Old May 19, 2004 | 09:19 PM
BlueRanger94's Avatar
BlueRanger94
Ok, but why 75W140?
Old May 20, 2004 | 12:03 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by BlueRanger94
Ok, but why 75W140?
Because it's synthetic. It meets a broader specifiction range. Why recommend synthetic and then specify a narrow specification range, when there are already many lubricants that meet the necessary specifications with a much broader range?
Old May 20, 2004 | 08:45 PM
Flash's Avatar
Flash
Ford recommends that your Limited Slip unit fluid be changed every 30,000 miles due to the friction modifier that is used. It absorbs moisture from the air and will condense water in the axle housing. Open or standard axles do not have this requirement, only the LS.
Old May 23, 2004 | 08:55 AM
pmees's Avatar
pmees
My suggestion is to go to Le-inc.com and look at their products. It really depends on the conditions.
Old Jun 1, 2004 | 02:56 PM
superrangerman2002's Avatar
superrangerman2002
I just happened to look at my owners manual yesterday.
It states that the front 8.8" open diff on my truck takes 75w90 dino juice, but the rear 9.75'' open diff is supposed to take 75w140 synthetic!
How is the dino juice good enough for one axel, but not the other? (i realize the that the front diff doesnt run all the time, but the shafts in side the diff do.)
Too me this seems very contradicting.
Old Jun 1, 2004 | 05:55 PM
cobrah's Avatar
cobrah
Red face hummmm...
Ya know you could probably run most any type of fluid (without any noticable differance) in the front and back...for awhile.
But Ford has Tech's that specialize in the area of "gear contact" "pivot points" friction and wear. Research has demanded specs from manufactures to be within very close tolerances when it comes to a protecting gear lube.
I can assure you it's millions of dollars worth of business for gear lube manufactures. They all compete for the recomendations from Ford, Chevy and all car producers.
Ford has a engineering dept. that runs front and back ends with multiable- gear lubes at very high speeds and under adverse conditions. The objective is to try an destroy the gears.
A S.P.C.chart is maintained on each lube used, then compaired to many manfactures. This chart will indicate what lube is best to use... to Ford these charts are the bible!
Stick with the book, and do some research for yourself on lube specs. you will be amazed as to how complex a lube. can be.
cobrah
Old Jun 1, 2004 | 09:35 PM
superrangerman2002
Come on, an oil revolution did not happen over night.
You make it sound as if my rear end will implode because I use a dino 85w140.
As an engineer, I can assure you that dino gear oils can and do work as well as thier syn counterparts for lubrication in a gear box. A 85-140 dino lubricates the EXACT same way a 85-140 syn....Fords tests are geared for specific weights of oils, not wether its syn or dino.
Most of the wear in a rear end doesnt come from a oil wearing out....it acutally comes from the fine metal dust that is suspended in the oil, this is why you change out your diff fluid.
Do you really think that the tolerances in my rear end are tighter than my front differential, thus needing a syn gear lube as you have suggested? .
Just cause Ford recomends the most expensive gear lube, it in no way, shape, or form, means that its the only one capable for the job.
Not one person has given solid evidence on why a syn is needed in a rearend, just the popular syn is better lines.
Old Jun 1, 2004 | 09:45 PM
ATC_250SX's Avatar
ATC_250SX
Well, id hate to but in but im gonna anyways, I personaly dont run synthetic in my truck, however, I do in my dirtbike, I am new to the syn. line, but, the lubrication atvandages seem to be much higher with the synthetic, for instance, my bike is 2 stroke, and I run a premix of 50:1 thats with synthetic, when I was running "DINO" I had to run minumum of 32:1 thats as lean as i could go, and if youve ever seen a bike running 32:1, well you actually cant see it, so from what ive been told and read from my spectro dealer, and also the amsoil dealer in town, the synthetic is supposed to lubricate better and stand up to heat, and shear, better, but im interested to hear what other people think, so i plan on following this thread, then maby ill have to change my truck over.
Old Jun 2, 2004 | 08:40 AM
cobrah's Avatar
cobrah
Talking
front differential, thus needing a syn gear lube as you have suDo you really think that the tolerances in my rear end are tighter than my ggested? .
My arguement is ...
Statistical Process Control (SPC) has proven the better grades, as I have said " you could use any gear lube" maybe for the duration of your ownership of your vehicle and may never experience a rear end explosion.
As far as tollerances front and back, and are they really a need for two types of gear lube?
Under lab. conditions "you betcha"!!! So why not under normal driving conditions? You will then have the satisfaction of knowing you are using the best lube...whats a few bucks more for the better?
I will admit your point is well taken but, as a secondary alternative only.
cobrah (Use da book on this one)
Old Jun 6, 2004 | 07:35 AM
Camille Marquis's Avatar
Camille Marquis
may have something to do with the way that the diff is disconnected don't know how just a guess. Syn might be too slippery for the clutch or what ever is in there.Syn also has a much higher burn temp.
Old Jun 9, 2004 | 11:14 AM
tmorris1's Avatar
tmorris1
Mobil One in that grade is $15-16 a quart!
Its only $6-8 qt here.
Old Jun 10, 2004 | 10:37 PM
peppy's Avatar
peppy
Originally Posted by peppy
Every 100k miles. Only if I could treat my truck right. I'm lucky to go 6 months. A reminder to change the fluid each time you submerg your differential, so the engineers say. If you stay high and dry, yea......stuff lasts about as long as anything else in or on your truck.
Changed it in March......here we go again....changing it in June. Man I gotta keep this thing above the water.......stupid floods. Again, thats why I use namebrand, but not topend stuff.
Old Jun 11, 2004 | 07:59 AM
  #28
tmorris1's Avatar
tmorris1
You would have to submerge it deap enough to get water into the vent tube, correct? Most vents are pretty high up in the frame. You would have water close to coming in the doors.
Old Jun 11, 2004 | 08:46 PM
  #29
peppy's Avatar
peppy
Yea, water almost in the doors, and at a good speed its all thrown up everywhere....but its so much fun.
My buddy actually got his truck thru water over the hood. No way I was gonna put my truck thru that much water.
newfie4ever
1997 - 2003 F150
23
Jun 20, 2016 08:04 PM
reptar0077
Jun 13, 2016 03:22 PM
generalee31184
21
Jan 10, 2016 06:08 AM
VaFordman26
Sep 9, 2013 10:27 PM
dirtmonkey11
Oct 21, 2009 04:24 PM
