Sponsored by: Real Truck
Help ID Rear Diff Tag for Fluids
Old Jun 9, 2016 | 07:50 PM
reptar0077's Avatar
reptar0077
Need some help identifying my rear diff for changing out fluids.
On a 2003 F-250 4x4 4 door, long Bed.
Rear Diff tag says
V 414 F
S 10 5 5618
Also a anyone have any recommendations for a nothing fancy, good priced rear cover replacement?
Thanks in advance!!
Old Jun 9, 2016 | 10:46 PM
fordmerc's Avatar
fordmerc
There are two tags on these rear ends. One is the one you gave us (kind of) and there is also a fluid tag that should tell you the diff needs 75w140 synthetic fluid.
On the other tag, there should be a code that gives you the axle ratio as well as if it is a limited slip. For example, if it were a 3.73 ratio with a limited slip, the tag would read 3 L 73. Look at the tag you have again to confirm.
If it has a limited slip, you will also have to add friction modifier. Even if the fluid you use says it has it in it, I would add a little more as the fluids tend to be light on the modifier.
As for a cover, look for an aluminum finned cover off a 2008. You will need longer bolts to make it work but the cover can be had off ebay for around $50.
Old Jun 9, 2016 | 11:01 PM
DND58's Avatar
DND58
Hope this helps with the cover and procedure. I used this cover and the Mobile with no additional friction modifier on my 02.
https://www.ford-trucks.com/forums/8...with-pics.html
Old Jun 10, 2016 | 08:34 PM
reptar0077's Avatar
reptar0077
Awesome thank you guys for the help!
I did see that other tag and it says W 140 synthetic only.
So 75-140.
I also found that my door tag has axle code 31, I'm pretty sure is a Dana rear end.
So for a cover is their more than one Dana model for a cover?
Edit: It's a Dana 10.5 after seeing 10 5 on my diff tag.
Off to eBay to purchase a cover!
Old Jun 12, 2016 | 02:18 PM
fishbones182's Avatar
fishbones182
Run 75-140 royal purple has friction modifier in it so no need to add it. Their diff oils are great in both of my trucks front and rear axles.
Old Jun 12, 2016 | 07:02 PM
fordmerc's Avatar
fordmerc
So 75-140.
Your rear diff is a Sterling brand. Your front diff would be a Dana 60.
Usually SRW F-350's are the ones with Sterling 10.5 rears and the f-250's get a Sterling 10.25 rear.
Old Jun 13, 2016 | 12:58 AM
reptar0077's Avatar
reptar0077
I would but in my "smaller" town O'Reillys auto parts wants 20$ per bottle! That's a lot!
Gonna go check my local Napa tomorrow for a cheaper synthetic alternative. I don't even think mobile 1 would be that much. Granted O'Reillys isn't the best place to buy fluids.
Old Jun 13, 2016 | 01:03 AM
reptar0077's Avatar
reptar0077
I'm not saying your wrong at all, how did you come to that conclusion? Are you saying the door sticker axle code 31 is always for the front axle? Thanks
Old Jun 13, 2016 | 04:50 AM
redford's Avatar
redford
FTE Leadership Emeritus
Your rear axle is a Sterling 10.5, not a 10.25. The front is a Dana 60.
Are you sure your code isn't 37 or 3L?
AXLE CODES:
37- 3.73
3L- 3.73 LS
41- 4.10
4N- 4.10 LS
43- 4.30
4L- 4.30 LS
48- 4.88
8L- 4.88 LS
53- 5.38
5L- 5.38 LS
Old Jun 13, 2016 | 03:22 PM
fishbones182
Advanced auto parts if one not in your town they ship for free. Use promo code trt30 for 30% off up to a 50 dollar savings or join their speed perks deal and use trt41 for 40.00 off a 100 or more purchase. Figure it up both ways see which would save you more.
mattnj
Sep 23, 2018 03:38 PM
adam10
Feb 4, 2012 11:30 AM
desrcr
Jul 2, 2006 07:53 PM
metalmechanix
16
Jan 4, 2005 12:56 PM
dalton
Sep 18, 2003 08:39 AM
