Oil & Lubrication
synthetic grease
Old May 11, 2004 | 07:46 PM
jkorreck's Avatar
jkorreck
synthetic grease
Saw a tube of mobil 1 synthetic grease in the parts store yesterday. I like mobil 1 oil and think it does a better job in protecting the motor but I was wondering if anyone had used the mobil 1 grease for balljoints, tie rods or wheel bearings and what they thought of it. ("I'm about to do a brake job including new rotors on my van, and since that means I'm replacing the races I think I'm going to replace the bearings as well)
Old May 11, 2004 | 09:36 PM
Ecuri's Avatar
Ecuri
I think it resists oxidation beter than petroleum. I know it resists heat a lot better. I use it exclusively for wheel bearings... I tend to heat the brakes sometime. I doubt it makes a difference on suspension joint life, though.
Old May 12, 2004 | 09:00 AM
MrBSS's Avatar
MrBSS
I have long used the Mobil 1 grease. I think it is very good grease, but actually, I am just projecting from the Mobil 1 oil. My useage of grease is so small, that the cost is not noticeable.
You should know, however, that Mobil 1 grease does NOT meet the Ford spec for wheel bearings. I'm sure it would work, but it does not contain the Moly component that the Ford spec requires. I now use a Valvoline synthetic grease that does also contain Moly, and so meets the Ford spec.
Old May 12, 2004 | 09:32 AM
jimandmandy's Avatar
jimandmandy
Mobilgrease 28 synthetic aircraft grease mainly has advantages in extreme cold, as is found at high altitiude. I would think the automotive product would also work best in extreme cold. I use the Valvoline because it meets the Ford spec.
Jim
Old May 12, 2004 | 04:24 PM
jkorreck's Avatar
jkorreck
Good to know, I think I'll go with vavoline synthetic grease just so I meet spec then. Thanks for the info.
TxMav
Apr 26, 2016 09:03 AM
sxrfun
Nov 12, 2015 08:42 AM
SpringerPop
147
Aug 6, 2015 02:16 AM
MJScore
Jan 21, 2015 05:34 AM
Supercab
Jul 20, 2014 07:00 AM
