Power Steering Flush
Old Jan 17, 2015 | 09:16 PM
MJScore's Avatar
MJScore
I'm getting ready to flush my power steering. What Mercon V oil do you recommend? I was thinking synthetic (Mobil 1) but is it worth it?
Old Jan 17, 2015 | 10:45 PM
whitetmw's Avatar
whitetmw
I just use the FoMoCo Mercon-V. I service mile when I do the transmission maintenance.
I'm looking for a video I found that shows the front of the truck off the ground a inch or sow which makes it very east to do while moving the wheel back and forth. Only takes half the time or less to flush it bright red.
Old Jan 17, 2015 | 10:56 PM
SARDiverDan's Avatar
SARDiverDan
I use Mobil 1 in mine. If you are parked on smooth concrete (like a garage) just slip a section of cardboard under each tire and the wheel is a breeze to turn as there is very little friction at the tire. Saves you the time of jacking it up
Old Jan 18, 2015 | 02:17 AM
scotttahoe's Avatar
scotttahoe
Here is a vid that Trey did for us on how to change the fluid.
Old Jan 20, 2015 | 06:32 PM
petrokiller's Avatar
petrokiller
Good tip on the cardboard Dan.
Thanks Trey for the video. Mine is starting to have a little whine I think.
Old Jan 21, 2015 | 05:34 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Get the cheapest Mercon V available, and keep changing it regularly. The recipe is all the same. Spending more $ doesn't make the Mercon V better!
Good luck!
murraydav
Sep 15, 2015 08:10 AM
Shade
Jun 19, 2008 07:39 PM
luvemhot
Mar 30, 2007 09:09 PM
Bubbatruck
Jan 24, 2007 01:45 AM
lasher
Aerostar
29
Nov 16, 2005 11:45 AM
