351W / Headers
Old May 11, 2004 | 05:20 AM
jsslasj's Avatar
jsslasj
Question 351W / Headers
What is a good brand of headers? That would fit properly without mods and will allow me to retain all smog equipment. Its just time replace that worn out exaust.
Old May 11, 2004 | 06:10 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
What about junk yard? It seems like you should be able to get a decent pair there. Other than that don't forget to check with this site's sponsors.
Old May 12, 2004 | 12:58 AM
jsslasj's Avatar
jsslasj
Thanks SCOTTInTexas
Old May 12, 2004 | 04:16 PM
clay01's Avatar
clay01
Summit Racing sells a set of shortie headders for the 351W truck. I think they are about $160. You did'nt state the year of your truck but they should work.
Old May 14, 2004 | 04:51 AM
jsslasj's Avatar
jsslasj
Its a 84 F-150 4x4 with a 351W. Thanks for the reply clay01
Old May 29, 2004 | 08:59 AM
nkuf250's Avatar
nkuf250
headers
I have an 85 f250 with a 351W and i have hedman.. but they last about a year where I live in the midwest.. and there a pain...
Old May 31, 2004 | 02:11 PM
jwf1999's Avatar
jwf1999
I have a pair of Hooker Competition headers on my truck and it was a pretty clean install once the manifolds came off. They cleared the frame beautifully on my 82' f-150. the only problem was the oil dipstick was in the way which isnt that hard to work around. They gave me a good 15-20 horse also by adding them and gave it a much meaner sound.
Old May 31, 2004 | 02:44 PM
bigbrown84truck's Avatar
bigbrown84truck
headers suck, you always have to worry about gaskets and crap, plus on a ford they seem to like to cook starters.
Old May 31, 2004 | 06:51 PM
jwf1999's Avatar
jwf1999
Ive had my headers in for a few months now and havent had a problem yet with gaskets. The trick to make the gaskets last long is buy 2 sets one metal and one paper gasket set. Coat both sides of each gasket in grease as it will help them seal when it heats up. Put the metal gasket towards the engine and the paper towards the header. And then just check the header bolts periodically every month or so.
Old Jun 4, 2004 | 12:09 PM
Bruce P's Avatar
Bruce P
Exclamation Header
If you want trouble free headers go with a good brand name (I used hedman, Hooker is now getting better too) and go ceramic coated. Ceramic: Excelllent heat dissappation and therefore resist warping which causes the gasket to fail. If you are seroius about keeping the truck and don't what to be tightening bolts or replacing gaskets, go with the ceramic coated headers. They cost more but reduce the headaches. Plus they resist rusting. Regular headers will start rusting two days after you put them on and use them and you will see
Bruce P.
Old Jun 4, 2004 | 12:10 PM
Bruce P's Avatar
Bruce P
Exclamation Header
If you want trouble free headers go with a good brand name (I used hedman, Hooker is now getting better too) and go ceramic coated. Ceramic: Excelllent heat dissappation and therefore resist warping which causes the gasket to fail. If you are serious about keeping the truck and don't what to be tightening bolts or replacing gaskets, go with the ceramic coated headers. They cost more but reduce the headaches. Plus they resist rusting. Regular headers will start rusting two days after you put them on and use them and you will see
Bruce P.
Old Jun 4, 2004 | 10:28 PM
jwf1999's Avatar
jwf1999
Aye i have the black painted headers and the Paint heats up and chips off within the first hour of running with them. As for the warping i havent had that problem yet. But the Hooker Competition header's have been trouble free for me for over 4 months now.
guidoamm
Feb 15, 2015 08:52 AM
david00f150
1966 - 1977 Early Broncos
May 30, 2010 02:49 PM
Munch
1997 - 2003 F150
Oct 14, 2007 09:37 AM
imlowr2
Jan 18, 2006 08:12 PM
FB2
Bronco II
Nov 30, 2001 11:38 AM
