What is a good brand of headers? That would fit properly without mods and will allow me to retain all smog equipment. Its just time replace that worn out exaust.
Summit Racing sells a set of shortie headders for the 351W truck. I think they are about $160. You did'nt state the year of your truck but they should work.
I have a pair of Hooker Competition headers on my truck and it was a pretty clean install once the manifolds came off. They cleared the frame beautifully on my 82' f-150. the only problem was the oil dipstick was in the way which isnt that hard to work around. They gave me a good 15-20 horse also by adding them and gave it a much meaner sound.
Ive had my headers in for a few months now and havent had a problem yet with gaskets. The trick to make the gaskets last long is buy 2 sets one metal and one paper gasket set. Coat both sides of each gasket in grease as it will help them seal when it heats up. Put the metal gasket towards the engine and the paper towards the header. And then just check the header bolts periodically every month or so.
If you want trouble free headers go with a good brand name (I used hedman, Hooker is now getting better too) and go ceramic coated. Ceramic: Excelllent heat dissappation and therefore resist warping which causes the gasket to fail. If you are seroius about keeping the truck and don't what to be tightening bolts or replacing gaskets, go with the ceramic coated headers. They cost more but reduce the headaches. Plus they resist rusting. Regular headers will start rusting two days after you put them on and use them and you will see
If you want trouble free headers go with a good brand name (I used hedman, Hooker is now getting better too) and go ceramic coated. Ceramic: Excelllent heat dissappation and therefore resist warping which causes the gasket to fail. If you are serious about keeping the truck and don't what to be tightening bolts or replacing gaskets, go with the ceramic coated headers. They cost more but reduce the headaches. Plus they resist rusting. Regular headers will start rusting two days after you put them on and use them and you will see
Aye i have the black painted headers and the Paint heats up and chips off within the first hour of running with them. As for the warping i havent had that problem yet. But the Hooker Competition header's have been trouble free for me for over 4 months now.
