I just purchased a set of Sanderson headers. The headers didn't come with bolts because I purchased the set from a friend. Sanderson does not recommend stainless bolts for whatever reason, they say to use grade 8 header bolts. I prefer the stainless one by ARP or just using standard allen heads. Is there a problem with stainless, or even using stainless allen head bolts?
im a union ironworker & have been in it for over 24 years now..i do alot of Nuclear power plants..car plants..etc etc..maintenance & build..we deal alot with stainless bolts..anyone that has alot of experiance with stainless bolts will tell you that once a stainless bolt has been put in something..it is almost impossible to take back out & re-use again..something to do with the way it acts with environment..when backin it out..feels like the threads have been scarred..especialy when applied to a carbon nut or threaded bore...i would go with a good high tension carbon bolt
If you want the stainless, apply lots of HIGH TEMP NICKLE BEARING anti-sieze.
Yes, it's different from regular grey anti-sieze.
Go with a mid grade 5 or so bolt. Its all the strength you will prob need for the headers. Use anti-seize as someone else here mentioned and you can also seal the inner side of the threaded end after installation with a super high temp rtv sealant. This will keep out debris and condensation which doesnt help you later if you are trying to remove the completely rust welded bolt out. Problem with stainless steel is it is too soft. Very pretty to look at but tend to really react poorly to constant expansion and contracting due to the extreme temperatures they are exposed to. Tendency not to shear but to stick and you can actually twist the bolt (looks interesting...lol)when it is stuck tight. If you go with too high a grade like an 8 or higher they tend to become brittle over time and heat and can actually shear during use or when attempting to remove them. Have experieced both but a quick trip to the local engine shop and a few healy coils later all is good...hehe. good luck.
Hey imlowr, Are you certain that Sanderson says to use grade 8, or does it possibly say "Stage 8 Header Bolts". Stage 8 is a company that makes locking header bolts that really work well, check em out!
My system is to use stainless studs. 9They can be had in any hardness found in other bolts.) The problem of galling, as described above is avoided by using brass or bronze nuts and stainless flat washers. Always easy to remove the nuts but you will have to double nut the studs to get them out.
