Roller lifters...
Old May 7, 2004 | 10:43 AM
javi2001's Avatar
javi2001
Roller lifters...
Hi all, I was wondering: Is possible change a standar lifter by a roller lifter??? I'll some more mods??? it will work with same cam?? I have hear it will give a bit more power...
Thanks
Old May 7, 2004 | 12:08 PM
Silver Streak's Avatar
Silver Streak
You'll have to have a cam custom made for roller lifters. In order to get this done someone must be producing roller cam blanks for the 300, which I don't think anyone is. You'll also need better valvesprings, shorter push rods, and a special distributor gear. Roller lifters from a 302 should work since the regular lifter is the same as a 302. Roller lifters won't work on a regular cam.
Old May 7, 2004 | 07:15 PM
tetraruby300's Avatar
tetraruby300
I believe Crane has roller blanks for the 300.
Old May 7, 2004 | 07:23 PM
fordborn's Avatar
fordborn
They will give you a smother open and close and less wear on cam and lifters but alone there will not be a noticble increase in HP.
Old May 8, 2004 | 03:21 PM
Ford_Six's Avatar
Ford_Six
The main advantage of roller lifters is the cam can have a much longer duration. Since there isn't a sharp edge to worry about on the lifter, the ramp up and down can be very steep, so the duration at max lift can be much longer. A regular tappet style cam is actually tapered a little, to force the lifter to rotate and wear evenly. If you use a roller against that, you will wear the cam and roller out very quickly, and you will not see any of the benefits of a roller cam.
I believe Superior makes custom roller cams for the 300-6 also. I haven't checked the spacing of the lifters, but I don't think that 302 lifters will work without making custom tie plates.
Old May 11, 2004 | 03:56 PM
javi2001's Avatar
javi2001
Ok I'll make some extra reserch...
Thanks guys...
1bad67sbf
Apr 21, 2010 09:02 PM
gonzo
13
Nov 24, 2006 08:19 AM
Huntersbo
Sep 24, 2005 07:28 PM
79_ford_400_guy
Oct 14, 2003 08:37 PM
airharley
Apr 22, 2002 05:18 AM
