1992 Ford 351 Windsor
Old Nov 20, 2006 | 08:53 PM
gonzo's Avatar
gonzo
Does a 1992 351 Windsor have the raise lifter bores for roller lifters and the tapped holes to hold a lifter hold down spider? I can get this motor cheap and was wondering if i can make it a roller!
Thanks,
Gonzo
Old Nov 20, 2006 | 09:58 PM
Conanski's Avatar
Conanski
No. You can make it a roller motor but you need the small base circle cam and special linked lifters. Not worth it IMO, when the flat tappet cams come so close in performance.
Old Nov 21, 2006 | 04:58 AM
HemiEater's Avatar
HemiEater
Hope I'm not stepping on any toes here, but you only need a small base circle cam if you are useing a non rollor block with factory lifter. if he uses the linked lifter he can run any rollor cam.
Old Nov 21, 2006 | 01:08 PM
Conanski's Avatar
Conanski
Hey.. my toes are tuff!! The roller cam conversion kits I have seen had the linked lifters, I never thought of using OEM Ford lifters. Not sure how the spider would bolt down in a non-roller block, but that's not to say it can't be done. In any event, buying the lifters, cam and pushrods to convert a non roller motor could cost 3 times what a flat tappet cam and lifter set would,(new parts), that was my main point.
Old Nov 21, 2006 | 04:52 PM
HemiEater's Avatar
HemiEater
i couldn't agree more....Thats why I run solids they are cheep....
Old Nov 21, 2006 | 05:13 PM
gonzo's Avatar
gonzo
I was just hoping the newer 351w's had the provisions already. Did any 351w's go roller like the 5.0's?
Old Nov 21, 2006 | 05:23 PM
HemiEater's Avatar
HemiEater
I believe they went rollor in 94...there is a few posts active right how with the info on what years they started the rollor blocks.
Old Nov 21, 2006 | 07:37 PM
mhg's Avatar
mhg
i dont know when it started but my 96 has a roller cam in it
Old Nov 22, 2006 | 11:13 PM
GypsyR's Avatar
GypsyR
"Roller capable" 351W blocks started in 1994. Engine casting codes starting with "F4TE-". Not all of them had roller cams (IE Lightning trucks didn't) but the blocks all had the raised lifter bores and such to make installing an OEM roller cam setup straightforward.
Old Nov 23, 2006 | 09:07 AM
petes79f150's Avatar
petes79f150
On installing retro-fit roller setup: http://compcams.com/Technical/Instru.../Files/177.pdf
Pete
Old Nov 23, 2006 | 12:01 PM
Junkaxel's Avatar
Junkaxel
Two things that've been overlooked.
1. How cheap can you get it for?
2. Will buying link lifters eat all the money you saved over buying a roller block?
Old Nov 23, 2006 | 02:24 PM
gonzo's Avatar
gonzo
I can get the 92 351w, good working low mile for 200 bucks... i had already had in my garage the roller set up. I dont wanna get the comp cam retro to expensive. So by the looks of it i need a 94 and newer 351w. I wanted to spend the few extra dollars I would of had left on for a carbed intake.
Old Nov 23, 2006 | 08:38 PM
baddad457's Avatar
baddad457
Crane's linkbar hydraulic roller lifters will run you $425 a set. These are the only chioce as far as I know when trying to run a std base circle hydraulic roller cam in a non roller block. To run a solid roller, you'd also have to add in the cost of screw in studs, guide plates and machinework.
Old Nov 24, 2006 | 08:19 AM
EPNCSU2006's Avatar
EPNCSU2006
I've seen some 93's with the F4TE block
timbersteel
Oct 16, 2014 11:57 PM
GONZO86
24
Dec 5, 2008 12:59 PM
gonzo
Nov 19, 2006 10:41 AM
funfor
Feb 10, 2006 08:42 AM
airharley
Apr 22, 2002 05:18 AM
