roller lifters
Old Oct 9, 2003 | 11:29 AM
79_ford_400_guy's Avatar
79_ford_400_guy
roller lifters
will roller lifters give me that mch more horse? thanks
Old Oct 9, 2003 | 12:13 PM
bubbaf250's Avatar
bubbaf250
A roller cam (designed for roller lifters) could give you a lot more power than a flat tappet cam, especially if the rest of the engine is built to take advantage of it.
Roller cams are expensive, and they are not worthwhile in an otherwise stock engine.
Old Oct 9, 2003 | 01:54 PM
Ecuri's Avatar
Ecuri
I know nothing about these animals either,
what is "a lot more power" how much and where in the power band?
What other mod's would you think would be appropriate in a roller equiped engine?
Thanks
Old Oct 10, 2003 | 10:06 AM
Bill_Beyer's Avatar
Bill_Beyer
Roller camshafts have different profiles than flat tappet camshafts. Because of the action of the roller which is on the end of the lifter engine builders are able to take advantage of the much steeper ramp angles that can be achieved with roller lifters to open & close the valve more quickly. Since the valve can be opened & closed faster that also means that it can be left open longer allowing more airflow into & out of the engine.
OK, those are the facts. What follws is my opinion so it could be fiction but given the fact that we know the C (and M) heads flow much better stock than most any other Ford heads, I think that roller cams would work very well on stock heads provided the rest of the valvetrain was built accordingly i.e. a good (3 angle) valve job, roller rockers with consistent ratios and valve springs matched to the cam profile. Of course if you were building an engine like this you would definitely need a better induction & extraction system (4V carb & headers).
Old Oct 10, 2003 | 04:29 PM
bubbaf250's Avatar
bubbaf250
You can get all sorts of lobe profiles on a roller cam, just like on a flat tappet cam, so "how much" power and "where" depends on the lobe profiles you choose. If you go radical, you can go way more radical with a roller cam than you can with a flat tappet cam. And at the upper end, you can get performance from a hydraulic roller cam that is similar to what you would get from a solid flat tappet cam (higher rpm without valve float).
Other than the usual things you should do if you're contemplating serious high performance, roller cams require special roller lifters that retrofit into the block, special pushrods much shorter than stock length because the lifters are taller than stock, high pressure valve springs to control the added inertia of the heavier roller lifters, and rocker arms that can handle 2-4 times the stock valve spring pressure.
Using a roller cam in an engine that was not designed for it (like any 335-series engine) gets expensive. An off-the-shelf cam and lifter kit alone starts at about $600.
Old Oct 13, 2003 | 02:40 PM
ranchero77's Avatar
ranchero77
if your serious about a radical engine build up, go for it. personaly I went with a set of motorsport 1.73 roller rockers I picked up in Carlise PA for 200 bucks. it made a small yet noticable difference. but the engine noise was greatly reduced.
Old Oct 14, 2003 | 08:37 PM
79_custom's Avatar
79_custom
Yea That foresure true< I installed a set of roller rockers in my 351m, I could tell real fast, and I couldnt get over how it reduced the noise in the engine.. It was like everything was running on silk.. I couldnt tell really on the power wise.. I id say maybe it freed up 10 horse, It wasnt nothing you could feel.. but it sure made the engine alot smoother..
1bad67sbf
Apr 21, 2010 09:02 PM
breisr
Nov 11, 2006 10:23 AM
Huntersbo
Sep 24, 2005 07:28 PM
nate5812
Oct 15, 2004 09:44 AM
airharley
Apr 22, 2002 05:18 AM
