Rear diff. seals
Old May 2, 2004 | 11:45 AM
chrono4's Avatar
chrono4
Rear diff. seals
I'm rebiulding a 88 f150 and i've flushed and changed the rear diff. oil but now theres a pretty steady drip comming for the front seal going out to the drive shaft. I was just curios if anyone else has noticed it. thanks. Drew
Old May 2, 2004 | 01:07 PM
MustangGT221's Avatar
MustangGT221
If anyone else has noticed it? What do you mean?
It's not a common problem, its just that you need to re-place that seal if it's leaking.
Old May 2, 2004 | 09:40 PM
chrono4's Avatar
chrono4
Yea i was just curious if anyone else was having or have had that problem. Thanks
Old May 3, 2004 | 01:42 AM
MustangGT221
Yup, it happens when the seal is bad....pretty straight forward situation
Old May 3, 2004 | 01:06 PM
muxpux's Avatar
muxpux
i have the same problem. i was wondering how i drain/replace gear oil in the diff? theres no plug there. at least that i can see. i have a 78 bronco, 9" rearend i believe. also what type gear oil? and any estimate on how much the seal is?
Old May 3, 2004 | 04:51 PM
chrono4's Avatar
chrono4
if your broncos rearend is like mine then to drain you have to take the rear coverplate off to drain the oil and to refill it afterwards there is a plug on the frontside about half way down. i didnt see mine at first because it blended in due to the thick mud on it. i use 80w 90 castrol. i dont no about the seal yet. hope this hepls
Old May 3, 2004 | 04:55 PM
pops_91710's Avatar
pops_91710
chrono4, what you need is a pinion seal. I replaced a couple before. Drop the drive line, remove the yoke, pop out the seal, put in the new seal. Piece o' cake.
Old May 8, 2004 | 08:50 AM
chrono4's Avatar
chrono4
thanks pops, gonna havto do that soon cause im loosin fluid fast.
Wrecklesswisdom
35
May 19, 2016 09:52 PM
Sharkster54
Apr 17, 2016 08:58 PM
robert_l_ross
May 14, 2015 03:28 PM
highboy390fe
1997 - 2003 F150
Oct 13, 2011 09:48 PM
metal_mullisha
Jul 10, 2006 10:26 PM
