Leaking rear diff
Old May 14, 2015 | 10:08 AM
robert_l_ross's Avatar
robert_l_ross
Leaking rear diff
While under the truck the other day, I discovered that what I thought was a leak from the rear diff cover is actually a leak from the bearing (?) or seal (?) where the drive shaft enters the diff.
...will it be cheaper to replace the rear axle or tear apart the diff and replace the bearing/seal?
Old May 14, 2015 | 10:15 AM
SuperDutyScaler's Avatar
SuperDutyScaler
The pinion seal is only around $12 and the new crush sleeve is another $10ish.... U must get a inch pound gauge and take a measurement with the old parts on then install new seal and crush sleep tighten and check inch pound reading. Go a little at a time till it goes back to where it was if you go more than the original reading you will have to buy another crush sleeve and start over. It's not very hard at all
iPhone from IB AutoGroup
Old May 14, 2015 | 10:27 AM
WE3ZS's Avatar
WE3ZS
Sean did a write up here a few years ago. https://www.ford-trucks.com/forums/1...nion-seal.html
This is what I used when I installed a new pinion seal in my leaky 4.88 axle housing before I swapped it under my EX.
Old May 14, 2015 | 02:48 PM
holeshotwalt's Avatar
holeshotwalt
Gee Rob, that old age thing must be creeping up if you're starting to have rear-end leakage... next step will be stocking up on geriatric Depends! (so I've heard)
Old May 14, 2015 | 03:28 PM
justonv's Avatar
justonv
Replacing the pinion seal itself isn't too bad. I would definitely do that rather than buying a used rear end that you don't know anything about. It is probably less than 30 dollars of parts for the seal, crush sleeve, and pinion nut. If you don't want to do it, I would think a shop wouldn't even charge too much for something like that.
66f100restoration
Jul 25, 2018 09:36 PM
68bluebeast
Nov 7, 2012 09:18 AM
wreckinball
May 13, 2011 10:13 PM
MoyockPowerstroke
Oct 18, 2009 01:19 PM
Technocrsr
Oct 12, 2007 06:36 PM
