rear axle seals
Having just replaced both rear wheel bearings on my 2003 2WD, the seals are on the ends of the axle tube by the brakes. I borrowed a seal puller from Auto Zone at no cost.
The axle shaft will have to come out but it's not that hard to do. There are good write ups on how to do it.
Last edited by Ultramagdan; 10-12-2011 at 07:06 AM. Reason: Link to competing site.
I had to buy the Bearing Repair Kit for mine, because at 145000 miles the rear bearings went bad and started wearing away the axle where they turned.
The "kit" is actually just a longer wheel bearing, which allows the bearing to ride in a different non-worn spot on the axle. The way it is designed, like you said, it also moved the seal to a non-worn area.
The name brand made in USA bearings were only 29.99 each from O'Reilly Auto Parts, and included the new seals also.
Well, for the last year or so I was hearing a humming noise and just thought it was the rear end. It was more noticeable as my speed would increase. Having the L/S rear end, I just thought it was due to getting worn out with 145000 miles.
When I found the posts about the rear axles, I checked mine and found them to be what was causing the hum.
I did have a "chatter" and "clunk" from the rear end, but that has not reoccurred since I put the Ford rear axle fluid and the modifier in after finishing the bearings. Been about 5000 miles now.
fatheroftwo
03-10-2016 11:56 AM
clhart426
08-29-2011 12:46 PM
51truck
02-22-2003 10:11 PM
