351m engine problems
Old Apr 5, 2004 | 11:37 PM
tye sheats's Avatar
tye sheats
hi, I have a 77 ford f-100 4x4 with a 351m in it. I just recently did a paint job on the out side of the truck. every once in a while the truck is hard to start and if it starts it has a lack of power and dies at idol. now this only happens once every week or two but its stating to TICK me off, I just put in a new electric choke 600 cfm edelbrock carb, but not sure if that is the problem? thanks for the help tye...
Old Apr 5, 2004 | 11:45 PM
Mil1ion's Avatar
Mil1ion
Sounds like a High-miler and it maybe need a timing chain & gear replacement
Old Apr 6, 2004 | 09:36 AM
beartracks's Avatar
beartracks
If the problem is intermittant I would suspect ignition or possibly fuel delivery.
Old Apr 6, 2004 | 10:09 AM
77300i6's Avatar
77300i6
your fast idle or air/fuel mixture may be incorrect
Old Apr 6, 2004 | 10:15 PM
tye sheats's Avatar
tye sheats
ow now i have a new problem not sure if they are related though, but there is oil comin out of my exhaust would that be a head gasket job?? thanks tye
Old Apr 6, 2004 | 10:48 PM
LxMan1's Avatar
LxMan1
Usually either bad valve guide seals or worn piston rings.
Old Apr 7, 2004 | 12:14 PM
dfisher1's Avatar
dfisher1
Tye,
What do you mean, "You have oil coming out the exhaust"?
Are you burning oil? Is it dripping out the exhaust?
Secondly, clean your battery cables. After a paint job, overspray can get into the battery connections and cause a weak connections. This is an unlikely problem but possible.
Change your fuel filter.
Lastly, It is possible for the ignition module to fail intermittently. Buy a module now and keep it in the truck. You'll thank me later.
KingFisher
Old Apr 7, 2004 | 12:45 PM
jwrboss302's Avatar
jwrboss302
I agree, buy an ignition module, preferably a Ford one and stick it in the truck. You will be grateful someday.
JWR
Old Apr 7, 2004 | 11:12 PM
tye sheats's Avatar
tye sheats
thanks alot for the replys guys, um yes oil/mix was coming out of the exhaust but I fugured out what it was. I washed down the engine to clear som paint particles and the water built up om my intake and went down into my exhaust manifold opps, lol. and then i figured some gas mixed in it to becasue the carb overflowed so there is a nice little mixture of oil/water/gas. is there suppose to be a hole in the top of the manifold?
1993_f350_2013
Dec 10, 2018 04:18 PM
baker1983
Jan 12, 2016 11:17 AM
tye1911
Jun 21, 2015 07:31 PM
Faulker120687
19
Apr 4, 2015 03:27 PM
1993_f350_2013
6.4L Power Stroke Diesel
30
Nov 10, 2013 04:47 PM
