Hard Starting?
Old Jun 21, 2015 | 07:06 AM
tye1911's Avatar
tye1911
6th Gear
Hard Starting?
Please help! Hello everyone I am new to the form. I have a 1984 F150 Short bed, step side with a 300/6. Hard starting, after it sits over night. Once it’s started and warmed up it runs fine, what are any possible solutions?
Old Jun 21, 2015 | 08:16 AM
DeereFord300's Avatar
DeereFord300
The mechanical fuel pump could be losing its prime. You can confirm this if you disconnect the line from the pump and put a small gas tank under the hood and hook it up to the carb. If you can start the truck quickly with this setup then the fuel pump is bad. It could also be a misadjusted choke system
Old Jun 21, 2015 | 01:48 PM
Franklin2's Avatar
Franklin2
You would think the carb would have a little fuel left in it from just overnight. What about your choke? Is it working?
Old Jun 21, 2015 | 06:41 PM
maytag906's Avatar
maytag906
How are you starting it? You need to pump the pedal once or twice, to set the choke, and also prime the engine. Unlike a newer fuel injected vehicle.
Old Jun 21, 2015 | 06:50 PM
anthonym92's Avatar
anthonym92
how do you prime the engine? i have problems starting after sitting overnight too....
Old Jun 21, 2015 | 07:12 PM
Franklin2's Avatar
Franklin2
Pumping the pedal before cranking squirts gas into the engine, and also sets the choke to closed.
Old Jun 21, 2015 | 07:31 PM
anthonym92's Avatar
anthonym92
ohhhhh.....now that i know that haha. thanks franklin
lauxg
32
Nov 27, 2017 07:09 AM
Signgonzo
Nov 27, 2016 11:25 AM
Gonu50
1997 - 2003 F150
Mar 3, 2013 04:49 PM
TexinCali
Jan 5, 2013 09:35 PM
chaas
Mar 27, 2007 08:53 PM
