What's the difference?
what are the differences between the I-6 they put in trucks and the I-6 they use for generators and other industrial uses? is it possible to put and industrial motor into a truck? I can get a practically brand new industrial I-6.
The plate on the motor says
Type: B6PF-6005-A
Options: S0-31
what will it take to make it work in a truck?
Type: B6PF-6005-A
Options: S0-31
The industrials (from what I've read) have a forged crank. It would be a stronger unit than the regular truck engine - which is saying a lot! Hold out & see if someone can verify that with the engine code.
Swapping on your accessories should be all it would take. I'm no expert - I'd advise waiting for futher opinions & input. However, if the price is right, you probably can't go wrong!
broncr
broncr
on
Only difference in the later industrial engines is the lower 8:1 compression ratio, the oil pan, and possibly the exhaust manifold(no forged crank, ah well...) They are essentialy what came in 1986 F-Series equipped for leaded gas(they still sold 'em in Canada) Duraspark II, Carter YF(not YFA,) forged pistons, no EGR or AIR pump, rated at 124 HP @ 3600, 241 ft/lb @ 2000(same as a truck.)
Basicly, if your truck is carbed, bolt on your power steering brackets(alternator bracket is more desireable, stamped steel, no AIR pump bracket, and the alt. sits farther from the exhaust manifold) and truck engine mounts, flywheel, clutch and bellhousing, then send that puppy home.
on
SuperTruckUSA
Vendor Specials, Discounts, Product Announcements & Group Buys
01-13-2016 10:31 AM
