4 cly Ford Industrial motor
Old Jul 27, 2015 | 07:50 PM
FarmwomenMoline's Avatar
FarmwomenMoline
We have an older Gehl skidloader that has a Ford Industrial 4 cly gas engine...the motor is comparable to a 1970 Pinto only industrial. How do we get the distributor off? We removed one bolt and took the clip off but it won't come off.....PLEASE help...we use it every day and need to get it back up and running....
Old Jul 28, 2015 | 09:37 AM
f5fordgirl's Avatar
f5fordgirl
Assuming that engine gets lots of moisture on it, so penetrating oil and some light hammer tapping. Might take some time, but with luck you can get it out without breaking it.
Old Aug 3, 2015 | 12:49 AM
treemanF700's Avatar
treemanF700
tap tap tap wiggle wiggle wiggle.......
Old Oct 23, 2015 | 02:46 PM
Beanscoot's Avatar
Beanscoot
Maybe source a Pinto distributor first, so that if the old distributor is so stuck that it gets broken coming out you can be up and running again quickly.
Hopefully the distributors would be similar enough to be interchangeable or you could make one good one from the two.
BTFordGuy302
23
Jun 2, 2016 05:16 AM
dave2180
Feb 7, 2009 08:44 PM
junkyardjeff
Oct 6, 2005 06:39 AM
eandaauto
Jun 1, 2004 11:17 PM
Matt
Dec 17, 1999 02:27 PM
