1978 - 1996 Big Bronco
Voltage loss on window switches.
Old Mar 23, 2004 | 04:08 PM
Broncobirdy's Avatar
Broncobirdy
Ok at stop light while in drive, I powerdown the window. No problem. If the window is down and I use the switch in the down position the voltage drops down from "A" to "O" on the normal. The fuel pump changes pitch also during the switch movement. The battery connections are tight...Is this an alternator going bad? It drops alot more when under a full load like A/C, Highbeams, and radio. The battery is 2 years old maybe. It came from Wally World. Any comments?
Old Mar 23, 2004 | 05:10 PM
dyarumian's Avatar
dyarumian
mine does it too, those little moters draw allot af amps
Old Mar 23, 2004 | 09:33 PM
JBronco's Avatar
JBronco
They all do it. Nothing to worry about unless the needle goes into the red.
H/O alternator is the "fix" if it bugs you though.
RSA7.3
1983 - 2012 Ranger & B-Series
Jan 8, 2017 12:16 PM
quincyj34
Sep 30, 2014 07:30 PM
svt2205
2009 - 2014 F150
21
Sep 19, 2014 04:07 AM
Truck Guy99
Sep 5, 2013 11:03 AM
a64armt
Jun 1, 2006 07:38 PM
